- Paint Codes
26 -
Last visited
Days Won
1
Exterior Paint Colors
Classifieds
Everything posted by GRS from Kzoo
Cruise Control Repairs
GRS from Kzoo replied to GRS from Kzoo's topic in 986 Series (Boxster, Boxster S)
McKinlay, I'm glad to see, even after all these years, that the all the posting saved somebody a lot of headaches (as well as backaches crawling under the instrument panel). I actually still think about the silly way Porsche engineered the cruise control circuit almost every time I'm out driving my car. -
I had pretty well forgotten about that! I think there's a lesson for all of you out there that you'll want to think twice about doing any business with the firm named in my post of August 10, 2007. Their claim that my unit checked out bad is very suspicious, especially since they now seem to have one listed for sale at $289 + $15 shipping. Looks like they have changed their name but the link in that earlier post will take you to their site. They did not charge me for their "analysis" but by telling me the eprom was fried they got me to let them keep it to avoid paying $100 for their effort. Very suspicious! -
I can finally report success and unequivocally state that a dead light bulb in the instrument panel will render the cruise control inoperative on a 1998 Boxster! After 5 years, many hours and hundreds of dollars it is all working again. I am thrilled but feel like a fool since I have actually had a spare light bulb in my ash tray the entire time. Thanks once again to everybody here. -
Jon, One more thing... Do you happen to have the part number for the bulb? I see three different bulb numbers for the cluster! GRS -
I'm anxious to get to this as soon as I have the use of two hands again. I'm presuming you are referring to the instrument cluster removal at http://boxsters.addr.com/hacks/cluster.htm and that the mesh thing is the grill to the left of the speedometer. Can you describe the baggie method? I've had the cluster off before to replace lights in the IP but never needed to use a baggie for anything. GRS -
No I haven't but you've giving me sufficient motivation to replace the bulb as soon as I can use my hand again. (I had surgery on my right hand to repair my thumb after an injury and this will take a couple months to heal). Thanks 00BoxsterS! -
Well, I received a used cruise control module from a recycler in Wisconsin, installed it, and the cruise on my car still doesn't work. Same symptoms as before, no green light, no functions (and I put about 800 miles on the car this weekend for a thorough test). Before removing it, I again checked out the pins on the harness connector and everything is still as it was before (per my post on July 14), even to the point where Pin C has less than 12 volts (although this time it was 11.63 and the brake switch had been replaced with a new one). The module was guaranteed so I will pack it up and get a refund, but this does have me wondering what I may have missed. Power, ground and all switch functions (both for the stalk and pedals) all check out OK. I have a few other used modules lined up to try but this has me quite baffled and thinking I must have missed something. Any other suggestions out there? Thanks, GRS -
Well, after testing the part, Auto and Truck Electronics tells me that the unit is not repairable as the eprom is shot and they cannot replace that (probably because they do not have the software to put in it). Looks like I need to find a new unit. Leads me to wonder what would have caused the eprom to go. The only thing I can figure is an electrical glitch in the power supply to it. I did need to replace the ignition switch as I had erratic operability of things like the HVAC fan. Since I was in the habit of leaving the cruise stalk "on" switch in the on position, do you think the ignition switch issue could have led to the failure of the cruise control ECU? Once it's fixed I'll be sure to keep it off when not in use. Thanks to all on this board for your help. I've learned a lot and at least I feel certain that I've got to the root cause of the problem. GRS -
Just an update... After resoldering a few questionable solder joints and still not getting any voltage out of pin "K", I've shipped off the ECU to Auto & Truck Electronics in West Palm Beach, Florida for rebuild (www.autoecu.com). They rebuild all sorts of automotive controllers and gave me a price of $229 to do the job, which includes a 1 year warranty. Best I was able to find for used ECUs is $250-300. I'll let you know how it works out. GRS -
OK, I finally have more to report! I replaced the brake switch a couple of weeks ago, and it made no difference (but then again I don't think any of us expected it to). BTW, the four terminal switch appears to have replaced the three terminal version which was originally in my car and is what I installed. Today I was finally able to locate a control unit from a dismantler ($200), which motivated me to get the old one out and look at it. Not so easy to get out, but if it helps somebody in the future, here's the steps I took: 1) Remove the duct that runs transversely from the HVAC unit to the left side of the footwell. 2) Remove the visible screw in the remaining duct to the HVAC and pull it aside to observe the controller. 3) There are three 10 mm bolts holding the control unit to key-slotted holes in the brake pedal bracket. Loosen the top two 1/2 turn or less and leave them in place. (These are the harder two to access). Remove the third bolt entirely. I found that I could not remove the unit with this bolt in place as it made it too difficult to get sufficient clearance to pull out the controller. 4) Pull the entire controller (still attached to the throttle pedal) down. 5) The electronic control unit is held to the controller by four phillips head screws at its corners. Of course, the part number on my unit (996-617-021-04) is not the same as the one the dismantler has (996-618-051-02). First question: Does anyone out there know if the dismantler's part will work on my '98? In looking my unit over closely I did find one transistor which appears to have a weak solder joint at its connection to the top of the board, although the corresponding joint at the bottom of the board looks fine. I'm no EE, but it seems like that may be an issue, especially since there do not appear to be any traces to that lead on the bottom. Hopefully, I can get someone who knows to look at it. Any thoughts? Thanks again for all of the help so far. GRS -
OK, checking out the voltages between pin E and the others, here's what I get: Pin H – Supply – should have 12v+ when the ignition is switched on. YES! Pin D – Set/Acc – should have 12v+ when the ignition is switched on, the cruise switch is depressed on the end of the stalk, and the lever is pushed to set/acc. YES! Pin B – Off - should have 12v+ when the ignition is switched on, the cruise switch is depressed on the end of the stalk, and the lever is pulled to off. I have just the opposite, pin B gives 12v with ignition on but goes to 0 when I pull the lever to off. Pin G - should have 12v+ when the ignition is switched on, the cruise switch is depressed on the end of the stalk, and the lever is lowered to resume. YES! Pin F – Clutch Switch - should have 12v+ when the ignition is switched on and the clutch is depressed. Again, I have the opposite, it is 12v with the ignition on and the clutch up and 0v when the clutch is depressed. Pin A – Speed Signal – I think this is a pulse which will vary with speed, and would be difficult to test. If your other speed-related devices (spoiler etc) are working, I would assume this to be OK. I did not check anything on this. Pin C – Stop Light Switch - should have 12v+ when the brake pedal is pressed. Very interesting, here I only get 11.58v, which is .6 less than the others. I'm pretty certain this is due to the brake switch situation where the normally closed terminals work reliably but the normally open terminals act a bit flaky. Pin J – Stop Light Switch - should have 12v+ when the brake pedal is up. YES! Pin K – Signal out to the Diagnostic Socket & Cluster Light – the control module should give a 12v+ signal out when the ignition is switched on and the cruise switch is depressed on the end of the stalk. It should also have 12v+ for a few seconds when the ignition is switched on with the cruise switch off. The connector would have to be plugged in to test this. I get 0 volts here, but did not try momentary on with ignition. I do not get the light to go on with a normal start bulb check. I also checked terminal 8 of the dignostic plug and do not get power on that pin either. So I think I have confirmed that the stalk switches all work. The reversal of function on pins B and F is interesting. Richard, can you confirm how they work on yours? I checked mine many times and figure if the logic is reversed it either means that the logic changed in the controller with a model year or my controller has problems. Does anybody have a lead on replacement controllers? I still plan to replace the brake switch but did not find one this week due to a little confusion over part numbers. According to the dealers, the switch listed for my '98 is supposed to be PN 996.613.114.01 but it apparently has 4 terminals, not 3 like the one in mine. I looked at my switch today and confirmed it is a 996.613.110.01, which appears on the list as the '97 model part. The connector for mine looks like it would work with the 4 pin version since it has a space without a terminal in the 4th position. Has anybody out there replaced a 3 terminal switch with a 4? As always, I look forward to your analysis. Thanks, GRS -
There is absolutely no cruise function insofar as setting or holding speed. I hoped that the non-functional light might have been a helpful clue for diagnosing the problem. If the switch on the end of the stalk were defective, I don't think the light would illuminate since it used to go on when the switch was depressed. From the circuit, it does appear that there could be other switch issues that would not have showed up by measuring continuity directly at the stalk switch as pins D and B both depend on the switch for power. I still haven't figured out where the cruise lamp gets its power from but it may get illuminated through the diagnostic pin K. With Richard's detailed Input/output list below, I should be able to verify whether any other of the switch functions beside on/off are at fault. If it checks out completely, the only thing left will be the controller. Thanks again for the insights. -
Thank you, Richard! This looks to be exactly what I need to thoroughly check it out. It may need to wait until next weekend before I can dig back into it, but I'll let you know how it goes. GRS -
Maybe this link will view directly on the page: Cruise Wiring Harness Connectivity -
OK, I've spent quite a few hours today digging into this (and may be ready to join the circus as a contortionist). No luck thus far getting the cruise to work, but here is what I have found: 1) Clutch switch appears to work fine when checked with a VOM when the connector is off. 2) Although my brake lights work fine (albeit only when the ignition is on) the brake switch appeared to act erratically with a VOM directly on the switch. I'll order a new one on Monday, but figured I would take it apart and see if I could at least determine what was wrong. The contacts were somewhat burned so I disassembled the switch elements, filed them clean and was actually able to get it all back together and seemingly functional with a VOM check. It is a three terminal switch (I think that's a SPST) with a copper terminal between two plated ones. The plated terminals are normally closed and the copper terminal is normally open, at least once I got it all together. I was very hopeful that I resolved the problem (at least for the time) but in a subsequent test drive I still did not get a green cruise control light or any cruise control function. 3) I popped off the cover from the cruise stalk and checked the switch operation directly at its terminals (with the control unit unplugged). The switch works fine! Then, using the diagram and the ohm meter on the control unit terminals, here is what I found for the wiring harness (perhaps this will be a useful reference someday): CruiseWiring (Note: I've did this as an Excel spreadsheet and then made an image of it to upload. Hopefully it will view properly, I'll check to see if it does.) Looking at the diagram and the chart together, much of this seems to make sense. Notice that a lot of the readings to the speed circuit terminal (A) get a resistance reading instead of open or closed. It also shows that when the cruise stalk main switch is closed, this closes the circuit to terminals C (stop light), E (circuit G162 which I'm guessing is the green dash light), F (clutch switch), H (power supply to controller) and J (another stop light switch). It seems reasonable that the main switch would direct power to those functions. As I said, I will get a new brake switch but since the terminal cleaning had no effect whatsoever I'm not very certain that this will take care of it and am still wondering if the control unit is the problem. Does anyone have any ideas about how to go about checking it (short of buying a new one)? The only thing I haven't done is pulled the dash apart to check the cruise indicator bulb but I can't imagine the failure of the bulb would cause the system not to function. Is that a reasonable assumption? The saga continues, comments are welcome (and encouraged). GRS -
I checked and the green light does not come on with the bulb check, but to be honest, I do not recall it ever coming on in the bulb check when the cruise was working. I'm going to look at it again from both the switch and the control unit connector this weekend. Thanks Tool Pants and Richard! -
Thanks to all for the input. I have the three stalk column, Tool Pants. I noticed in a previous string of posts that new column switch assemblies do not have the trim cover on the end of the cruise stalk. It looks like the on-off button in the end of the stalk is simply depressing a switch inside the end of the lever. Does that confirm what you have seen? Maybe I can just pry off the cover from the end of the lever to test the on-off switch? Richard, the brake lights on my car do work and I will check the clutch switch but I understood these to be the usual problems when the cruise doesn't work despite the indicator light on the dash being illuminated. Since my indicator light doesn't come on when I depress the switch at the end of the stalk lever, I've been assuming that I am not getting power to the system. The fuse is good, so based on the circuit that leaves the switch or the control unit (which I presume is what you call the actuator). From the diagram, it does appear that this is the best place to check it out, but I'm not sure what it looks like or where on the car it is located. Can you direct me to where it is fitted in the car? Thanks to all, GRS -
Thanks, Loren. This detail will make the cruise diagnosis a lot easier, but I do have one more question before I get back into it: To get at the cruise switch in the steering column, do I need to remove the steering wheel or is there a way to remove the upper and lower plastic trim from the steering column without taking off the wheel? (I'm referring to the trim around the column stalks with the rubber inserts around the stalks themselves). There is a small phillips head screw on either side of the column, but removing it did not allow me to easily pull the plastic halves apart. I had the air bag off today to repair the horn problem (thanks to this forum), but couldn't quite get to the cruise switch as I had hoped, at least without fear of breaking something. Thanks again for your help (and patience). GRS -
Loren, I tried getting back into this repair today and but I am having trouble figuring how to trace down the wires from the switch without knowing their colors or other way to identify them. I figured I could pull off the cover from the column stalk and get to the wires, but that doesn't seem to want to give up its disassembly secrets easily (and I really don't want to break it). Any hints on how best to check this out? GRS -
I've searched the forum and have seen several items related to cruise control installation and repair but haven't been able to find anything describing my particular problem. First, the car is a '98 with ~52,000 miles. The cruise stopped functioning more than a year ago. The green light on the dash will not illuminate when I depress the switch at the end of the stalk. The fuse is fine, I have checked it numerous times and even put a new one in despite not finding a problem with the old one. Other posts seem to have the green light working and I understand that the brake and clutch switches are usually the culprit for that problem. Does anyone have experience with failure at the switch? I figure it could be switch or relay related but without a circuit diagram do not know where to begin. Thanks, GRS
Bent V Lever?
GRS from Kzoo replied to GRS from Kzoo's topic in 986 Boxster Convertible Top Issues and Solutions
Thanks for both the tip and the instructions, Toolpants. I've got it all back together and functional and have been out enjoying the top down experience again. The clamshell is still a little twisted though, the driver's side being still a bit higher and further to the right than the passenger's throughout the up/down cycle, but the motor seems to have enough guts to pull it down when the cycle is done. Once the light goes out, the gap between the clamshell and the deck lid seems larger than before and the gap to the panel on the left edge is a little larger than the right. Any tips on final adjustment to pull this all back into place or am I being too picky? Thanks again! -
Bent V Lever?
UPDATE... Okay, so I finally receive the metal rod ends from Paragon late Friday to finish the top repair and I am all excited to get the car back up and out this weekend. Unfortunately, the new rod ends are not threaded deeply enough to provide the same adjusted length as the original red plastic ones. Both joints (on both rods) stop about three threads short of the tape which I had put on the rods to assure adjustment like the original. The holes in the new rod ends are actually deeper than than the plastic part but the threads are not tapped nearly close enough to the bottom. I know I could cut off a quarter inch of rod and take care of it that way, but it bugs me to chop up a second piece to fix a problem with the first. So I'll start tomorrow to find someone with a metric bottoming tap to finish the job. Has anyone else had this experience with the metal joint? I have emailed Paragon as it was the weekend and I supposed they wouldn't be there, but wanted the group to know of this potential problem. Also, there were no instructions with the joints as indicated at the Paragon site, but with the help here they are not too necessary. (Of course, it's a possibility that their instructions would tell me to cut off the rod I suppose)! BTW, thanks for the note on the picture sizes, Chris. Also, I had tried to upload with the Browse button in the June 3 @ 12:32 post that did not upload properly. Seemed pretty straightforward so I'm not sure what I could have done wrong. Oh well... Thanks again for all the help. I'll let the board know when I finally get this all done! GRS -
Bent V Lever?
Just to further clarify, I did not replace the cables proactively, but it was the first thing I did after this episode started. I had not noticed the bent V lever until I installed the left side cable. From your comments, I'm guessing that the cable was the first to actually go and the bent lever happened as a result. The loose fasteners and lubrication may have allowed some binding that caused the cable to pull from the motor. I was really surprised at how loose so many fasteners were. I'll keep an eye on them in the future. I have actually not broken either of the red joints, and they were on quite snugly, but I'll be chasing down a new lever and joint ends this week. With a little luck I'll be driving her again next weekend! (It rained all day today anyhow). As for the pictures, sorry about the size. Are there any recommended guidelines for picture size at this site? Upload seemed to take some time (even with my cable modem) so I may have made them too small trying to speed it up. Thanks again for all you help! -
Bent V Lever?
I tried to load the images I posted at the Kodak Gallery site and in the preview they worked just fine. Perhaps they are not accessible by linking in this manner to Renntech. When I just tried to put the URLs from there in the post, the preview bounced and indicated that the image formats were not acceptable. I've tried it again by uploading the same pictures to Flickr.com. Let's see if they link: The clamshell before I disconnected the pushrods. The adjustment screw which was not even finger tight. The left and right levers on my car. This picture linking stuff just seems a lot harder than it should be! Please be patient. Thanks again. -
Bent V Lever?
Thanks for the responses and sorry for the confusion. I was attempting to fill in the background after I already mentioned the status of the repair. I'll attempt to fill in the blanks and apologize if this gets too long-winded. I changed the cables after reading (on this site and others) about the certainty of the need to replace them on a 1998 Boxster. When I replaced the old cables, they were not broken but the cable jackets had definitely "stretched" with about 1/4 inch of cable on the motor end of the passenger side and 3/8 inch on the driver side, so it is possible that the timing slipped a tooth if the cable pulled out of the motor drive. I am not certain that the timing was off when the incident occured as the levers appeared to be in exactly the same positions dimensionally, but figure it must be now that I have changed the cables and I do plan to use the bubble level to get it right as I complete the repair. At the point of failure from the driver's seat and looking in the rear view mirror, all I could see is the top itself, not the clamshell. Since I had backed into the garage and the engine was still running, all I heard was the rumble of the idle. I did not hear any pops or noises that would have caused me to respond more quickly. Up until this incident I never had anything go wrong with the top and I have owned the car since it was new. When I got out of the car, the clamshell was still up, but higher on the left side than the right even though the canvas top had retracted: I can't honestly recall how low I was able to get the clamshell via the motor, but it would not go all the way down. Looking for what went wrong, the first thing I had noticed was that the lock nut on the screw shown here (right side) was very loose: Adjusting and tightening that screw had no effect on getting the clamshell down (heck, it seems to adjust the leading edge only about 2-3 mm with the clamshell is fully down) so I checked over at PPBB, which led me to the owner's manual procedure to disconnect the lever arms. Doing that, the clamshell would still not retract completely, staying 1 to 1.5 inches high on the driver's side. (That's why I concluded it is twisted). There is also a very small 'ding' in the clamshell on the left side which was definitely not there before and could have resulted from the twisting. I started the repairs yesterday with the cable replacement. The upper lever ball stud on the left side was visibly further from the large (~7 inch) plastic bushing (the one which holds down the spongy plastic insulation around the transmission) than that on the right side. Here is the photo I attempted to upload yesterday (thanks for the attachment instructions): Apparently, this has been seen before (thanks, Toolpants). I think I could probably get the pushrod re-connected despite the bent lever, but I wonder how much the bend affects the timing. I am guessing that the lever must be replaced or repaired before I go any further. Is this a good assumption, or has anybody attempted successfully to straighten one out? I am curious as to what the group thinks the sequence of the failure could have been. Besides two stretched cables and a bent lever, I found exceptionally loose fasteners at the aforementioned adjustement as well as the 4 phillips screws on each side which hold the worm and gear in place on the transmissions. Really loose, I'm talking 1/2 to one turn from finger tight! The three 13 mm flanged nuts which hold the transmissions in place were also very easy to back off. (I've reassembled the loose fasteners with 242 Loctite). I know that the cables are a known problem, but there were enough additional issues to make me wonder whether I need to be lubricating the slides at least once a year. I have never done that and there does appear to be plenty of grease on them. Thoughts? I guess I'm leading to the need to do preventative maintenance on the top assembly besides spraying it with waterproofing. BTW, my original top and rear window are in very good shape. The window is totally clear! I use the two step Maguiar cleaner and polish to keep the plastic very flexible. Another question I have is about the levers shown from KLA Engineering at Paragon products. Their site shows the complete lever assembly. Is that what they are selling or only the ends to replace the red plastic ones? I'll give them a call this week, but thought somebody out there would have the answer. Seventy bucks sounds too good to be true for the entire assembly! Thanks again for the help and insights!
