fredkhaz
Everything posted by fredkhaz
  1. What do you guys think about wheel spacers, and what size ?? on a 2010 997 Turbo.
  2. Thank you Loren, 2010 997.2
  3. Hello everyone, I just pick up a 997.2 Turbo form a friend for $46k with 75k miles on it, Looks like the PDK and all wheel drive controller oil was never changed, I am still waiting for confirmation from the dealer, Anyone knows if that is a easy DIY or dealer only??
  4. 2002 996 Twin Turbo, BASALT BLACK, have all records, Always garaged, 95k Highway miles, Ice cold A/C, Total of 4 Keys including 2 Carrera GT Keys, Xenon Headlight Tiptronic Transmission, Full Leather Package (Leather covered doors, dash, seat backs), Duel Power/Memory Seats, Alcantara Roof Liner, Sunroof, Porsche Crested Turbo Wheels, Tinted Windows Looks & runs great, Maintenance records available, Must see, Never seen snow, Well maintained, SpeedTech 70mm Hi-Flow Exhaust Mufflers. Here some more pix http://www.kodakgallery.com/gallery/creativeapps/slideShow/Main.jsp?sourceId=533754321803&cm_mmc=eMail-_-Share-_-Photos-_-Sharer
  5. Hello everyone, I am thinking to go with H&R springs on my 2002 996tt, its a daily car. now the question is should i got with the 19 inch wheels also? i have heard that i should stay with 18's on 996s ?? Avantgarde m310 http://www.sportslinkup.com/shop/0-Avantgarde-m310-1.html Thanks,
  6. Hello everyone .. I have a 2002 996 TT Tip and the outer right front CV boot is leaking and i couldn't find repair instruction yet, not sure if i am looking for it correctly also need instruction on how to replace the exhaust.. anyone ? Thanks.
  7. Hello everyone, I couldn't find a DIY on oil change on a 996 TT The book shows i can use 0W-40, 5W-40 or 5W-50. Does anyone know 1-How many places I need to drain oil from ?? I was told 3 places, 2 turbos and the motor. 2-Which oil should I use ? I live in So cal so the weather is between 60 and 90 degrees most of the time .
  8. Hello everyone, I just picked up a 996 TT with 88,000 miles on it (90k service was just dont $3k), replacing my 996 C2 with 181,000 miles on it. the ABS (passenger right corner) kicks in when i apply brakes when making a long right right turn. it feels that the brake paddle pushes back up also. I think i felt the same thing in my 996 C2 once or twice before but with the steering wheels was turned almost all the way left or right. Any idea ??? Now today i noticed that the PSM light comes on when that happens.
  9. Thanks but where does it say K&N is not legal in CA ?? I have the same Filter for my 996 C2 and passes smog every time :) K&N 57 SERIES GENERATION II FIPK COLD AIR INTAKE SYSTEM -- 50-state legal, C.A.R.B. exempted with E.O. number D-269-34; Provides additional power up to 23.80 h.p. at 5500 RPM; 96 to 99 percent filtration efficiency; Includes black roto molded intake tube, red air filter, heat shield, and all the necessary hardware for installation; Fuel injection performance kit; Features high density polyethylene intake tube that is custom engineered and aerodynamically designed to drive air into your engine; Its washable and reusable air filter is made of multiple interwoven layers of surgical cotton gauze infused or charged with oil for outstanding filtration and airflow; Comes with a heat shield that is custom designed to isolate and provide cooler air; Virtually eliminates intake tract restriction by replacing the air filter and the entire air path to the engine; Can go up to 100,000 miles between cleanings depending on driving conditions; Easy to install.
  10. Hello everyone, I just picked up a 2002 996 TT tip $25k with 88k miles on it as my daily driver...replacing my 2000 996 C2 tip with 181,000 miles on it. needs some work to make it mine. I really dont want to spend too much $$, i am looking at 1-Lowering (just for look) will never race it. I like the ride so i dont want it to change much just lower (H&R springs) 2-Exhaust (catback) (peedTech 70mm Hi-Flow Exhaust Mufflers Porsche 996 TT ) http://www.vividracing.com/catalog/speedtech-70mm-hiflow-exhaust-mufflers-porsche-p-113338.html 3-Cold Air Intake http://www.autopartswarehouse.com/search/?Ntt=cold%20air%20intake 4- Tint what do guys think ?? and what should i do with my old 996 C2 Tip with 181,000 miles on it ?? worth $12k ish
  11. great thx i was going to sell the 2000 996 cuz i got a 2002 996 TT but looking at all the rig u have i am having a 2nd thought ... hmm :drive: If you did not do so, you probably need to change the wear sensors. One on each side. And I think on a 2000 you can disconnect the battery for a few minutes to reset the computer. That should do it. Unless you changed the front brakes, and it is actually the rear brake sensors that are triggering the light? Good luck. DC
  12. Hello everyone, I have 2000 996 C2 Tip with 181,000 miles on it .. the brake wear light has been on for a while and i thought i need new brakes in the front so i just change the pads, but the light (Brake Wear) stays on.. is the dealer or a porsche mechanic the only one that can turn that light off ??
  13. Hello everyone, I have 2000 996 C2 Tip with 181,000 miles on it .. the brake wear light has been on for a while and i thought i need new brakes in the front so i just change the pads, but the light (Brake Wear) stays on.. is the dealer or a porsche mechanic the only one that can turn that light off ??
  14. thanks guys for all your inputs .. i have till wednesday to make up my mind could i put 2008 997 TT wheels on this 996 TT ???
  15. LOL i did not put the miles, has 88,000 miles mostly freeway he did 60 freeway miles each day to work and back for 5 years he doesnt work full time.
  16. no body work done .. i know the car since 2004 with 15000 miles on it .. just had a new transmission installed by the dealer ... where do u think i can get the trim parts ??
  17. Should i buy this 996 TT 2003 Tip 88k miles From a friend who just picked up his 2010 997 TT PDK yesterday (man that rig is sick fast) Dealer offered him $25k on trade. Which i can write him a check for. it has few cracked interior parts
  18. I driver it till it stops ... PDK that i was talking about is on the new 2010 997 TT not replacing my tip with a PDK Here is pix i took few min ago
  19. 180,000 miles all original :drive: http://www.renntech.org/forums/index.php?showtopic=31427 http://www.renntech.org/forums/index.php?showtopic=30151&st=0&gopid=159706entry159706 11/21/05 Windshield $395.07 5/10/06 Oil Change 102500 Miles 7/28/06 Altonator $300 and $60 Belt Tensioner 9/26/06 Paid off Loan 10/8/06 Oil Change 110500 Miles 9.3q $70 11/4/06 Back tires 265/35/18 Kumho ECSTA $300 2/1/07 Front Brakes 115000 Miles $350 2/22/07 Front tires Kumho ECSTA 116500 Miles 3/17/07 Oil Change 117500 Miles 9.3q $70 6/7/07 K & N Fileter 120,000 $450 10/1/07 Oil Change 125500 Miles 9.0q $70 10/31/07 Nexen N3000 Tires for rear 127000 Miles $300 (lasted 30k miles!) 11/11/07 Water Pump and Thermostat 127500 Miles $417 12/9/07 Window Regulator Passenger 128900 Miles $170.91 Sunset Imports 1/6/08 Spark Plugs and Row Mo30 and new plastic hard wear in front by tires 130,000 Miles 1/9/08 Windshield Repair 800-944-4577 // 714-992-9112 $50 1/30/08 Another Windshield Repair 800-944-4577 // 714-992-9112 $50 2/4/08 132000 Front Brakes (just pads) 3/16/08 134000 Oil Changes 15 W 50 9q 4/5/08 134500 new Battery and 4/5/08 Rear Brake pads only 5/1/08 134700 AOS - air oil separator $600 5/8/08 13500 Transmission Service $313 7/7/08 138479 Mileage check 7/23/08 139391 8/1/08 140000 Mileage check 8/23/08 141275 Miles Oil Changes 15 W 50 9q 11/7/08 145000 Mileage Check 11/26/08 146000 Mileage Check 1/17/09 148456 Oil Change 15 W 50 9.3q 3/23/09 152123 Mileage Check 4/13/09 153900 Mileage Check 5/17/09 155741 Oil Change 15 W 50 9.3q $70 5/25/09 156000 Front Brake pads and rotor. no sensor. 6/10/09 157000 Nexen Tires 225/40/18 Front 275/35/18 Rear $593.31 8/12/09 160269 Safelite Auto Glass 714-771-4159 $395.07 9/18/09 162412 Mileage Check 10/3/09 163372 serpentine belt 10/3/09 163372 Oil Change 15 W 50 9.5q 10/3/09 163372 Fuel Filter 10/3/09 163372 Cleaned K&N Filter 10/10/09 oxygen Sensor $155.20 10/10/09 Steer Lock $106.79 10/16/09 Newport Imports $165 bypass the kill switch and fix alarm remote 02/20/10 171548 Oil Change 15 W 50 9.5q 02/27/10 172000 Rear driver tire $171.37 4/25/10 176035 Fuel injection Cleaner 6/14/10 179346 Oil Change
  20. My old posting http://www.renntech....showtopic=31427 Yesterday (8/14/10) ya baby when is time for a 977 TT PDK ?? :drive: 11/21/05 Windshield $395.07 5/10/06 Oil Change 102500 Miles 7/28/06 Altonator $300 and $60 Belt Tensioner 9/26/06 Paid off Loan 10/8/06 Oil Change 110500 Miles 9.3q $70 11/4/06 Back tires 265/35/18 Kumho ECSTA $300 2/1/07 Front Brakes 115000 Miles $350 2/22/07 Front tires Kumho ECSTA 116500 Miles 3/17/07 Oil Change 117500 Miles 9.3q $70 6/7/07 K & N Fileter 120,000 $450 10/1/07 Oil Change 125500 Miles 9.0q $70 10/31/07 Nexen N3000 Tires for rear 127000 Miles $300 (lasted 30k miles!) 11/11/07 Water Pump and Thermostat 127500 Miles $417 12/9/07 Window Regulator Passenger 128900 Miles $170.91 Sunset Imports 1/6/08 Spark Plugs and Row Mo30 and new plastic hard wear in front by tires 130,000 Miles 1/9/08 Windshield Repair 800-944-4577 // 714-992-9112 $50 1/30/08 Another Windshield Repair 800-944-4577 // 714-992-9112 $50 2/4/08 132000 Front Brakes (just pads) 3/16/08 134000 Oil Changes 15 W 50 9q 4/5/08 134500 new Battery and 4/5/08 Rear Brake pads only 5/1/08 134700 AOS - air oil separator $600 5/8/08 13500 Transmission Service $313 7/7/08 138479 Mileage check 7/23/08 139391 8/1/08 140000 Mileage check 8/23/08 141275 Miles Oil Changes 15 W 50 9q 11/7/08 145000 Mileage Check 11/26/08 146000 Mileage Check 1/17/09 148456 Oil Change 15 W 50 9.3q 3/23/09 152123 Mileage Check 4/13/09 153900 Mileage Check 5/17/09 155741 Oil Change 15 W 50 9.3q $70 5/25/09 156000 Front Brake pads and rotor. no sensor. 6/10/09 157000 Nexen Tires 225/40/18 Front 275/35/18 Rear $593.31 8/12/09 160269 Safelite Auto Glass 714-771-4159 $395.07 9/18/09 162412 Mileage Check 10/3/09 163372 serpentine belt 10/3/09 163372 Oil Change 15 W 50 9.5q 10/3/09 163372 Fuel Filter 10/3/09 163372 Cleaned K&N Filter 10/10/09 oxygen Sensor $155.20 10/10/09 Steer Lock $106.79 10/16/09 Newport Imports $165 bypass the kill switch and fix alarm remote 02/20/10 171548 Oil Change 15 W 50 9.5q 02/27/10 172000 Rear driver tire $171.37 4/25/10 176035 Fuel injection Cleaner 6/14/10 179346 Oil Change
  21. ya i am on my 2nd set ... little loud but very good for a daily driver car
  22. Hello Everyone will hit 180,000 miles in few weeks
  23. Congrats! Regarding front brakes: 2/1/07 Front Brakes 115000 Miles $350 2/4/08 132000 Front Brakes (just pads) 5/25/09 156000 Front Brake pads and rotor. no sensor. Is this usual wear-and-tear? thanks brakes, yes just wear and tear
  24. Hello everyone on the way to work today old posting http://www.renntech.org/forums/index.php?s...mp;#entry159706
  25. i use to hand wash the car and dry with turtle wax and dry ever 2 or 3 days up to last year. but now i use the california duster every morning (always garaged) and i wash it ever week or even every other week. still hand wash and use the turtle wax and dry.
