superdough
Everything posted by superdough
  1. Worked, thanks!
  2. I just got a 2000 Boxster S and need the radio code. It is equipped with a CDR-220. Model number - 4462 Serial number - y5043600 Thanks for the help.
  3. That makes sense. I had some trouble with the ignition switch recently and I lubed it and it started working again. Last night I pulled the blower motor out. Do you know if it's safe to hook it up to a battery to test it before I plug it back in the car and order an ignition switch? by the way... I just bought the switch on ebay for $19.95. Hope I don't get screwed! http://cm.ebay.com/cm/ck/1065-29392-2357-0...em=120168075388" target="_blank">Ebay Item Ignition Switch (120168075388)
  4. That makes sense. I had some trouble with the ignition switch recently and I lubed it and it started working again. Last night I pulled the blower motor out. Do you know if it's safe to hook it up to a battery to test it before I plug it back in the car and order an ignition switch?
  5. I have a 2000 boxter and recently the blower fan quit working. The display works but no air. Also (and I don't know if they're related) the headlights quit working on dim. When I flip the switch to brights I get nothing, but If I hold back the turn switch for the manual high-beam, they come one. ??? I'm confused. Anyone know where to start?
