lightyear
    Boxster S
lightyear's Achievements
  1. Does anyone know if the Front and Rear Brake discs from a 987 S would fit on a 986 S as I've just been offered some half price but don't know wether to take the risk or not? Thanks
  2. Or remove the battery with the key in the on position. ...so last night I tried to disconnect the battery with the ignition in the on position, alarm goes off!!?? So I resolved to unplugging the the Siren and the Backup Battery instead. Couldn't find anything on here or anywhere on the Internet about the Backup battery, other than its position (which is right next to the main battery underneath the Siren unit - its not mentioned once in the Owners Manual (which is the US version) and I suspect might be something unique to the European version of the Boxster?). Its a real sod to get at too, just managed to squeeze my hand in-between what I think are some brake or cooling tubes tubes and pull out the plug, I disconnected the horn just for safe measure as well. So then unplugged the battery and finally pulled out the Alarm Module from under the passenger seat (incidentally you don't actually have to take the seat out of the car, I simply unbolted it, folded it and pushed it as far back in the cabin as it would go, this gives you enough room to get the module out). The unit itself seemed on first inspection completely fine, i.e it wasn't soaking wet, just a few tiny drop of moisture. Had a good look under the carpet just behind the well that the Unit sat in and its absolutely sodden. Im sure Im not the first to say this but I cannot believe what a bad design flaw the whole drains/carpet/alarm module is? Why put something like the Unit (that seems to control a lot of vital things on the car) in one of the lowest positions in the cab where it can easily get damp or wet? I get the impression a lot of people have had the same problem and I hope they've sorted this on the 987?? So took the Alarm module home with me last night (luckily I have a motorbike as a backup) and put my oven on to about 50C degrees C (125F) as recommended on one of the other post on here. When the oven reached its temperature, I turned it off and put the Circuit board in and left it over night to cool. I guess this is the only way you can properly get rid of any moisture thats gotten into the components, I don't think a hair dryer or heat gun would be as effective. Bought the unit back to work with me today and have just put it all back together, plugged in the battery and turned the key..... and she started, first time!!! The only problem now is that I've lost quite alot of confidence in a car which bought specifically because I thought it was bullet proof. OK I now know about clearing the drains etc and keeping an eye out for water on the floor, but I cant be stranded again. Thanks again for all the advice, you've saved me a small fortune in dealership bills.
  3. OK yes have just checked under the Passenger seat, the carpet surrounding the well that the unit sits in is still damp, although there appears to be no water lying there anymore (perhaps it has drained away slowly). Will attempt to remove the seat and unit later today. Reading Mike Fockes posts on his website http://mike.focke.googlepages.com/drainsdiagram he says that "...It also controls the ignition and a number of other functions" - so this may explain why the car is not starting?? Will let you know what happens, thanks for the advice, would have been a v expensive diagnostic from a Porsche dealer no doubt. OK, got the seat out and pulled out the module and the alarm goes off, so I disconnect the battery but the alarm is still going off (this is in the underground car park at work and its deafening!). So I quickly re connect everything and the alarm eventually stops. So how do I disable or stop the alarm going off? Thanks
  4. OK yes have just checked under the Passenger seat, the carpet surrounding the well that the unit sits in is still damp, although there appears to be no water lying there anymore (perhaps it has drained away slowly). Will attempt to remove the seat and unit later today. Reading Mike Fockes posts on his website http://mike.focke.googlepages.com/drainsdiagram he says that "...It also controls the ignition and a number of other functions" - so this may explain why the car is not starting?? Will let you know what happens, thanks for the advice, would have been a v expensive diagnostic from a Porsche dealer no doubt.
  5. I have a 2000 Boxster S, on Tuesday night at 1.30am the alarm goes off for no reason (it wasn't raining at this point although it did start shortly after and it has been a ridiculous amount recently in the UK). Drove to work the next day (in the rain) and all was fine, when I got to work the car wouldn't lock (well it would lock but would then immediately unlock and give a double beep of the horn). Went to drive home later that day and even though the dash lights lit up fine, when I turn the Key nothing. Now clearly the rain has affected the electrics somehow thats a given. I was just wondering if there is something obvious to check first. Have just checked most of the fuses until I pulled one out and the alarm went off so I stopped. Is there anything else? Just to note that I have noticed that for that past few months on and off, when I turned the key the starter wont engage immediately, I had just assumed it was me not turning the key enough as the Boxster ignition is quite stiff, but now I realise that perhaps it was related to the current problem. Could it simply need a squirt of WD40 in the keyhole? Thanks in advance.
  6. Try 5004 or 5002 Sorry, didnt seem to work (and I meant to put Becker 220, dunno if that makes any difference?
  7. Hi, usual story, lost Code Becker 1 CDR 200 - 4467 #Y5026257 Greatly Appreciated.
