hamisha
Everything posted by hamisha
  1. I recently returned from a week's holiday and found my 1998 996 C2, which had been locked in my garage, making a loud electronic 'bleep' (i.e. not a horn honk) every one-two minutes. I tried unlocking and locking the car again. This did not solve the problem. Neither did driving the car. This intermittent 'bleep' occurs whether the car is locked or not. The locking itself and alarm seem to work correctly, and the appropriate LEDs flash when locked. The underseat motion sensor and control unit were both replaced at my local OPC (due to an alarm fault) about 10 months ago, at a cost of over £700. Has anyone experienced this fault before? Is there anything I can do manually to reset the system or solve this problem? Is the only solution to send it back to the OPC? 1998 Porsche 996 C2 Coupe Manual RHD UK Specification
  2. Many thanks for your reponse RFM. How would I check whether the servo motor is working? Can I assume it isn't if the fan is blowing but no air is exiting the windscreen ventilation duct?
  3. I have a UK dealer supplied 2005 Cayenne 3.2 v6 with Tiptronic and automatic 2-zone air conditioning. Over the last couple of days (coincidentally since the car came back from a main dealer service, during which a service campaign 'upgrade' was carried out) the front windscreen de-mist function has stopped working. When the button is pressed, the fan speed increases and air is cut from the ventilation outlets, but no air comes out from the duct at the base of the windscreen. It's as if a duct or vent isn't opening to allow air to the screen. I've checked all the fuses, but all are in order. Any idea what could be causing this, and whether it's something that is easily fixed? Or is it another trip back to the dealer? Many thanks!
