azcarguy3k
Contact Methods
  • Website URL
    http://
  • ICQ
    Phoenix, AZ
    2002 Boxster S
azcarguy3k's Achievements
  1. I don't have any other faults and I went back to Autozone and had them erase the code. The ABS and PSM lights still come on, but the check engine light does not. Is the oxygen senser the likely problem? Thanks again.
  2. I have a 2002 Boxster S, 6 speed, 75k miles. My check engine light is on, I went to Autozone and they read code p0430 which their computer showed is related to the cat, or a vacuum issue. My PSM and ABS lights also come on after a few minutes of driving, but never when I start the car immediately. Any ideas on whether I have two separate issues or if there could be some connection between the two? I read on this forum that the PSM and ABS lights might be related to a bad or dirty MAF, so I pulled it out and cleaned it using MAF cleaner but it didn't seem to help. Any ideas? Thanks.
  3. I need to replace the plastic window in my 2002 Boxster. Does anyone know of a good place in Phoenix to have it done?
  4. Neither of those codes worked. Any other possibilities? Thanks
  5. Can you help me with my radio code as well? 2002 Boxster S Becker DCR - 220 4462 15000284 24/99 Thanks for the help
