fastcayenne
Everything posted by fastcayenne
  1. Cayenne 2006 V6. My Cayenne turned on the warning message of "check dipped beam and high beam" The left headlight does no turn on but the parking and signal lights do. My mechanic checked fuses,bulbs and wiring and everything was ok. He found under the drivers side dash a computer that regulates all electrical system. He manipulated this computer and the lights turned on, and he told me I need to change it. Do anyone knows the part number on this? Than you for the info.
  2. Hello, You can replace your pollen filter that is in the trunk. I had one of the center vents that was constantly drooping down and misdirecting the A/C. I took some velcro tape tape to fix the problem. You take the furry side and cut 1/2 inch strip off. Point the dropping vent all the way down and up the velcro on the exposed side. The you can roll the vent back to were you want it and it wont droop anymorre. Also the velcro will be hidden back behind the grill so nobody ever sees it. I removed the pollen filter and vacum cleaned it (needs replacement) but it didnt help. I think this foam flakes are some kind of isolation material of the a/c that is disentrigating. I fixed the a/c vents with velcro as you suggested.Thanks
  3. Hi there Im a new owner of a 1999 Carrera with 40K miles. i have noticed that there are some foamy flakes coming out of the A/C vents . Is it something i have to change like a filter? The air is ice cold. Do anyone knows how to adjust the loose center vent ? Thanks
  4. Try 9605 or 9603 :D BINGO!! 9607 did it Viva la musica! Thank you Loren
  5. Ok Loren I gave you the wrong info. The following is right from the radio: Becker CDR210 V5017156 Thanks again 1999 Black in Black Carrera 6 speed
  6. Newbie here 1999 Carrera C2 Black on Black 6 speed CDR-210 X5620082 Thank you
