usdmej
Everything posted by usdmej
  1. maybe you should take your old tires out on the track day before replacing them? sometimes having a tire with a lower amount of grip is better/safer/cheaper for beginners
  2. i'm hoping this wil fix my engine woes, can anyone show me a picture of the IAC valve so i can know what i'm looking for?
  3. I looked at your profile. A MY99 C2 is not egas so you have an idle control valve. Chances are this needs cleaning or the solenoid is bad and it needs replacing. Either way you should remove it clean it (and the throttle body while you are there). This process has been documented here many times so please do a search if you need details thanks for the tips loren, i found how-tos of the throttle body cleaning but i cant seem to locate insturctions on how to get to the idle control valve. can anyone help me out?
  4. how did u know it was a 99?!? =O its a C2
  5. whats up fellows, up until now my 996 has been nothing but reliable. but recently when i start it up in the morning the idle will go up and down until the engine warms up. after that all is fine. is this something that should be expected? ive got no cels or anything like that
  6. notice how the tire looks darker (less road debris embedded on it) on the outside compared to the inside. that means it's not contacting the road nearly as much as the inside tire is. expect the inner portion to wear away first, which is normal with p-cars unfortunately
  7. check your owners manual, there is a minimum engine RPM you're advised to upshift at. it's pretty high for first gear (close to 3000rpm i believe) because it's so long. but beyond that it's really driver preference
  8. man i love that spoiler!!! more pics please!!!
  9. sweet, is the console made out of plastic? any special steps needed to prep? i know www.bumperplugs.com claims a 14 step process they take to paint their consoles =X
  10. hi folks, i bought a new lip front and rear for my 996 C2 aerokit, i'm going to have it painted soon, i was wondering since i've seen body colored center armest consoles out there, can i just have the paintshop paint mine too? or are the pre-painted ones made out of a different material? tiy
  11. wow, you sure that wasn't a salesman that gave you that "advice"? so much for responsible fun = /
  12. well, hopefully there was no water in the key when u pressed it. if there was, you coudl have shorted the circuits and now need a new key. coincidentally i washed my volvo key last weekend, i didnt press any buttons, just opened it up and let it air dry. been using my spare key since never got around to putting it back together.
  13. i've called 3 dealers in LA and all 3 gave the same confidentiality story. Tool Pants would you mind finidng out the info for me if i gave you my VIN? i wouldnt mind paying your somethign for your help
  14. this is great news! are the plastic rivets bolt on? or do they require a special tool to install the lip? also OT, Loren have you ever been stumped by a question on this board =X
  15. my dad pulled out of the garage at a not so optimal angle and scraped up the lower lip pretty bad, then he told me later on the freeway it broke off and he ran over it -_____- do they sell just the Lower Spoiler part of it? where can i find it? i'm thinking about buying a couple and painting them flat black in the meantime so i can help him drive the car better.
  16. hi Folks, i have a 99 996, it only came with 1 key and that key only has 1 button on it. i called dealers to get a spare key, they charged anywhere from$300-500 (is this reasonable?) i've searched other threads and it looks like they all pertain to 2button remotes. TIA
  17. here is my stance on the situation i think 19inch wheels and tires were never listed as a recommended size by porsche, but porsche has never oficially said that they DONT recommend putting on 19" wheels/tires. think about it, 10+ years ago who was thinking about 19inch wheels? not that many people so porsche never R+D the possibilities. this car is mainly a daily driver, i'm well aware of matching the overall rolling diameter if i decide to change sizes, actually the 305-25-19 on there now has a smaller rolling diameter effectively lowering my gearing. not good for cruising at all. my original question is this. Looking at the width of my rear wheel, would a narrower tire fit?
  18. you should let us know what the companies name is even this early in the game since they're being apprehensive. are you the original owner? do you follow porsches recommended minimum upshift RPMs when driving?
  19. whats up fellas, i originally purchased this car second hand. i don't know how wide the rear wheels are, they are Work Brombachers, which come in a myriad of sizes. the tire on it now is a 305-25-19 i need to change them out soon, i want to get a taller tire with more sidewall, also i was wondering if i could make it narrower too, a 295 or maybe even a 285 section tire? here are some pics, tell me what you guys think i can get away with
  20. by removing the airbag you are already technically disabling it; hence the airbag warning light lighting up. there are plenty of racy looking aftermarket steering wheels out there you should look into it!
  21. sweet, looks like you didnt lose too much cargo area (besides the loss of a passenger seat) any reason you didnt go with grey carpet to match?
  22. swweeeeet! this car continues to amaze me with the tasteful mods! any idea how much it retailed for? just last week i discovered that instead of a porsche sports exhaust i actually have a complete gemballa exhaust B)
  23. 1999 996 C2 WORK W-ITS Brombacher 19" 3 piece wheels. it's their Porsche specific model and it comes in a whole lot of different sizes so i dont know how wide this one is. http://www.vividracing.com/catalog/work-br..._4607_5516.html
  24. i've checked the options on my 911, but none of them mention a wheel or pedals i know its a regular 4 spoke, but all other 4 spoke wheels i've seen arent so shaped around the rim. mine have thumbrests and perforated leather. is this an oem option? once again i've searched all aftermarket pedals and none look like this. anybody have a clue what they coudl be? thanks in advance fellas
  25. hey guys, this car was purchased with these tires. they are pirelli p-zero-rossos the rears are a massive 305-25-19 and i was wondering how many more miles were left in them? i was also wondering if i needed to replace them, can i go with a more narrow tire? tire rack doesnt even stock this size and i dont think i need a tire this wide. i'm not sure how wide the wheels are, can anyone tell me how i can find that out?
