dprantl
Everything posted by dprantl
  1. Get me the serial number and we can give it a try... I got two numbers from the back of the unit itself: POCR-1R0821899 V40821899B Dan '86 928S 5-spd w/LSD '93 968 Tiptronic Do you know if it is a 4 digit code? If so, try 0827 or 0825 Yes, I'm sure it's a 4-digit code since I've entered them before on other CR-1's. Unfortunately, with these radios you can only enter digits 1 - 6 so I would have no way of entering those codes. Thanks anyway :) Dan '86 928S 5-spd w/LSD '93 968 Tiptronic I don't know if this will be of any help, but I do have a busted CR-1 here which I know the code to: POCR-1P0114389 V30114389B Code 1226 Could you use this as a cross-reference of sorts? Dan '86 928S 5-spd w/LSD '93 968 Tiptronic Sorry... none of my decoders handle 6 digit results. You can try here - although they do charge for the service. http://www.car-audio-accessories.co.uk/por...radio-codes.php Er... what I meant was that the codes are 4-digit codes, but each digit can only range from 1 - 6 (since you enter the code using the preset buttons on the radio face, and there are only buttons 1 through 6). I'll check out that site, thanks. Dan '86 928S 5-spd w/LSD '93 968 Tiptronic
  2. Get me the serial number and we can give it a try... I got two numbers from the back of the unit itself: POCR-1R0821899 V40821899B Dan '86 928S 5-spd w/LSD '93 968 Tiptronic Do you know if it is a 4 digit code? If so, try 0827 or 0825 Yes, I'm sure it's a 4-digit code since I've entered them before on other CR-1's. Unfortunately, with these radios you can only enter digits 1 - 6 so I would have no way of entering those codes. Thanks anyway :) Dan '86 928S 5-spd w/LSD '93 968 Tiptronic I don't know if this will be of any help, but I do have a busted CR-1 here which I know the code to: POCR-1P0114389 V30114389B Code 1226 Could you use this as a cross-reference of sorts? Dan '86 928S 5-spd w/LSD '93 968 Tiptronic
  3. Get me the serial number and we can give it a try... I got two numbers from the back of the unit itself: POCR-1R0821899 V40821899B Dan '86 928S 5-spd w/LSD '93 968 Tiptronic Do you know if it is a 4 digit code? If so, try 0827 or 0825 Yes, I'm sure it's a 4-digit code since I've entered them before on other CR-1's. Unfortunately, with these radios you can only enter digits 1 - 6 so I would have no way of entering those codes. Thanks anyway :) Dan '86 928S 5-spd w/LSD '93 968 Tiptronic
  4. Get me the serial number and we can give it a try... I got two numbers from the back of the unit itself: POCR-1R0821899 V40821899B Dan '86 928S 5-spd w/LSD '93 968 Tiptronic
  5. I've read through this whole thread (phew). I guess since I have an older Porsche CR-1 radio without the code I am out of luck? Dan '86 928S 5-spd w/LSD '93 968 Tiptronic
