Seanpg
    New Haven
    1999 911 Cab
Seanpg's Achievements
  1. I'm also having this problem with my 1999 C2 Cab. Is there any way to have this fixed other than taking it to the dealer? It literally spits gas back out at me when I try to fill it up. Any help would be appreciated. Thanks! Sean
  2. Thanks - anyone have a link to where I could get the instructions? Thanks again
  3. Tried pulling up and down on the lever several times with no luck..... Since I'm a newbie, any detailed instructions you could provide on how to go about getting and then installing the switch would be really appreciated. THanks! Sean
  4. You're exactly right - when I engage the hand break, nothing happens. Is this something I'd have to get fixed at the dealer? Or is it something I could fix myself.
  5. Just bought a 1999 911 C2 Cab. When I bought it it had the hard top on. 1) Removed the hard top 2) I can open or close the top by inserting the key into the drivers side door and holding to one side 3) I can't open the top from the inside - here's what I'm doing a) insert key / turn engine on B) hand break is engaged c) press and hold the rocker switch to open or close d) The "convertible top light" on the dashboard - flashes... it doesn't go on and doesn't even flash in a consistant manner. The top won't open or close. Any ideas or should I call a dealer? Thanks in advance, Sean
