Fissionx
Everything posted by Fissionx
  1. Just changed the starter on my '99 911 and wanted to add a few things. Starter was slow to turn then progressed to screeching noise on start-up when cold. I ordered a remanufactured starter from suncoast for ~$630 with a $500 core refund, so essentially got a new starter for $130. A great deal IMO. Removal 3: Mark proper orientation of the throttle cable mounting bracket to the throttle body. The mount is sloped and can only properly be installed in one orientation (downward sloping towards you) 6/7: For the starter mounting bolts I was able to use just a single 2ft extension. The lower bolt looks tricky, but is easily accessible from underneath the alternator mounting bracket. I loosened the main belt and removed the alternator belt tensioner to insert the extension, then attached the socket. You MIGHT be able to get away with several smaller extensions. New unit works great! I wish I'd done it sooner since it was pretty cheap and easy job.
