jeberg
    Other
    '00 Porsche Boxster S 3,2
    '07 MB CLS 350
    '01 MB C180T
    '89 MB 240GD
    '67 MB 250 SL
    '56 MB 190 SL
  • Future cars
    '09 Ferrari California
jeberg's Achievements
  1. Did you get the PCM serial number off some paperwork or directly off the PCM? Sometimes a unit gets swapped out under warranty and the dealer forgets to give the owner the new card with the serial number and code. Best thing to do is to remove the PCM and check the serial number on the unit. Spot on, that did the trick - much obliged /Henrik
  2. Hi Loren, Just bought a '00 Boxster S with PCM/Navi on auction, however no codes (car was repo'ed and I got it dirt cheap) Read your advice that PCM codes can only be obtained via the dealer, so I called the local chaps and they kindly looked up the codes based on the VIN, but to no avail, as these codes do not unlock the unit. Dealer is at a loss. Do you by any chance know if there is a solution to this? Love your site, this is my first Porsche and I already learned a lot from browsing around in the forums. Cheers, Henrik
