m32
Everything posted by m32
  1. As always...thank you Loren! Edwin
  2. Loren, Oh ok... This is what i'm trying to do on a friend's 2008 turbo which is essentially convert the turn signals to white and run them as DRL's Edwin
  3. Does anyone know where I can find the wiring diagram and details for the 997TT front indicator lights? I want to do a project on rewiring the lights and am looking for the technical specs related to the lights (wattage, voltage, etc). Thanks Edwin
  4. My buddy got in a wreck and need to find the airbag control module on 2010 997 turbo. Anyone know where it is? Thanks Edwin
  5. Update: I cleared the error code on my brockway R1000 and it didn't come back. I have been driving it and noticed recently that when the car is running (rear decklid fan is on) but the moment I shut the car off, the fan shuts off. Is this right? I thought the cars fan should be running to keep the engine temp down? I noticed that 5 minutes after I shut off the car, the engine temp on my brockway unit was flashing at 194 degrees. The temp while driving seems normal (183 while driving but 189 while stopped at red lights). Does the error code (original post) have something to do with this? Thanks everyone Edwin
  6. Awesome...thanks for that. It's ok for me to keep driving the car no? Edwin
  7. I have a 01 996TT and I was driving into work this morning and my CEL came on. I read the code and it was showing P0480. This CEL popped up a week before when I was driving and I was really low on gas (which was the first time it showed up). Does anyone know what this code means and how to permanently fix the issue? Thanks in advance Edwin
  8. I am trying to take off the center console to get it painted but can't get the auto shift knob off. Any advice? I did a search but didnt find anything. Thanks
  9. Just a quick question... does anyone know if the various 997 model (non-turbo) have different rear widths in the back? Thanks
  10. 996.612.070.10 is for the Cab spoilers. Loren, Its an 02 996 cab and I got the 996.612.070.10 part as mentioned above Edwin That is correct harness for a MY02 ("Carrera" wing) on a Cab. That's odd then. I'm have no idea where to plug it into. Can anyone help? Thanks Edwin Thanks Loren. looks like I have to take off the wing... I appreciate the help Edwin
  11. 996.612.070.10 is for the Cab spoilers. Loren, Its an 02 996 cab and I got the 996.612.070.10 part as mentioned above Edwin That is correct harness for a MY02 ("Carrera" wing) on a Cab. That's odd then. I'm have no idea where to plug it into. Can anyone help? Thanks Edwin
  12. 996.612.070.10 is for the Cab spoilers. Loren, Its an 02 996 cab and I got the 996.612.070.10 part as mentioned above Edwin
  13. 996.612.070.10 is for the Cab spoilers. Loren, I got the plug in and I checked the part number and it is correct. The harness looks like this... not really sure where to plug it in. Any help? Thanks Edwin See the picture in the very first post of this thread. One end goes into the connector on the right side of the engine compartment (near the tail light). Pass the cable though harness guide and plug it into the socket on the spoiler/fan area. Loren, This is the only connector that I see on the passenger side rear taillight. It has about 12 pins or something. Did I get the wrong harness? Edwin
  14. 996.612.070.10 is for the Cab spoilers. Loren, I got the plug in and I checked the part number and it is correct. The harness looks like this... not really sure where to plug it in. Any help? Thanks Edwin
  15. Thanks Loren/Chuck. I checked the stalk again and it seems to work fine. I noticed this started happening after I started to use the trickle charger. I'll try to reset the battery and see what happens Edwin
  16. I have an 2001 996tt with 20k miles and it seems that everytime I start it up, the clock is in the mode that allows you to change the time. Anyone else have this issue? Edwin
  17. loren, i did a search and found this thread http://www.renntech.org/forums/index.php?s...+sunroof+switch it appears that the sunroof switch is ok. is there another thread i am missing? thanks Edwin
  18. Model and year please? and what are you looking for? power (+12 volts)? loren, It's for a 01 996tt and yes, I'm trying to find a switched power source for my radar. thanks! Edwin
  19. Does anyone have the wiring diagram for the sunroof switch? Thanks Edwin
  20. 996.612.070.10 is for the Cab spoilers. Loren, I called Suncoast and they said it's titled "harness, stop light". Will this harness get rid of that spoiler malfunction warning light on the dash? Thanks Edwin Yes, both the spoiler and all the rear lights run through the harness. Loren, The fixed spoiler has a brake light on it too. Will the harness cut that light out too then? Edwin
  21. 996.612.070.10 is for the Cab spoilers. Loren, I called Suncoast and they said it's titled "harness, stop light". Will this harness get rid of that spoiler malfunction warning light on the dash? Thanks Edwin Yes, both the spoiler and all the rear lights run through the harness. Thanks Loren. Where can I go to donate/contribute to this site? your help is invaluable Edwin
  22. 996.612.070.10 is for the Cab spoilers. Loren, I called Suncoast and they said it's titled "harness, stop light". Will this harness get rid of that spoiler malfunction warning light on the dash? Thanks Edwin
  23. Loren, My friend has an 2002 996 NB cab and we installed a fixed wing on it. I read your thread about two different harnesses. Can you tell me which one I need? Btw, I just called my local dealership and the price of the harness is $211.25 (ridiculous) Edwin
  24. Thanks Loren. Appreciate the help as always Edwin
