concept muffler
Everything posted by concept muffler
  1. thanks jp and others i found the problem , the relay was not sitting tight in the relay box i just pushed it back in and the lights turned off , thanks for all your guys help .
  2. thanks for all of your guys imputs but i still havent got to solving out what the problem is , i disconnected the switch and started the car and the headlights are still on , my lights are oem hid and my ignition seems ok , it turns freely without getting jammed. The day time running light feature kinda makes sense , but why would it just turn that funtion on , and how do you turn that off . I thought and i can be wrong if you disconnect the switch you turn off the power going to lights rendering them not to turn on , can i possibly have a short somewhere ?
  3. hey guys i have a 01 996 turbo and when i start the car the headlights /brake lights all turn on and i can not trun them off when the car is running when i shut off the car the lights turn off , also when i start the car the headlights turn but the guage light wont turn on unless i turn the headlight switch to the on position . what can be this problem ? thanks
  4. alex and james did some work on my 996 turbo , the flash is a must !!!!!! big difference from stock and i just ordered the gt2 clutch conversion from them this week these guys are very good at what they do i will continue to do work with them , alex also said the same thing you dont get much hp from the intake and it does make the maf go bad but they have a hitachi maf conversion that they do and its much more reliable , give them a call
  5. will a factory rollbar for a cab model fit into a 996 turbo hardtop ? what is the difference ? mounting position ? height ? thanks
  6. hey guys i need to know how to disable the airbag light im going to install a momo steering wheel without airbag thanks . opps i forgot to add my cars a 2001 911 turbo
  7. so i got the flash and alex and them at sharkwerks were great im getting .08 to 1.0 bar boost is that what u guys are getting for boost on a 01 nonx50
  8. thanks for your replys everyone im getting the flash done tomorrow and ill let you guys know how it goes .. bernie
  9. so im getting a ecu flash this month im thinking about going to sharkwerks in fremont to have them flash my 01 996 turbo any pros or cons of the evolution motorsport flash ? i hear its program is pretty good thank you in advance for your inputs
  10. hey guys i have to keep adding clutch fluid on my 01 996 turbo i looked under the car and cant really see where the leak is coming from ? it looks dry near the engine compartment and i see some fluid up front but i think its from when i overfilled it and thinking its just residue . any ideas thanks
  11. hey guys is your front trunk hood hard to close ie. you need to push down on the porsche crest pretty hard to get the hood to close or is this normal ? oh i have a 01 996 turbo . thanks
  12. i noticed that the 996 turbo tuners adjust the wastegates do they put evc's? or electronic boost controllers ? any pros and cons . thanks guys
  13. hey has any one tryed this company , micheal shaw ? do there products fit well ? and look like a high quality product ? or can anyone recommend some other companys thanks http://mashaw.biz/Coachwork996.asp
  14. hey guys im stuck , i tryed to bleed to the system on the rear tail and i think i made it worse now it doesnt go up at all it used to go up crooked and the cylinder was leaking on one side i know im bleeding it wrong what is the correct step by step way to bleed the spoiler an easier way to do this .thanks for your help. bernie
  15. i figured it out for some reason the speedo wire to the radio wasnt working correctly ? i dont know why but i tapped into the speedo wire behind the instrument wire and now everything works so for anyone looking for the speedo wire it is pin 13 , blue plug thank you
  16. for a second there i thought it was a 997 looks good man
  17. yeah thats the first thing i checked i was hoping that was the problem but it wasnt all the connections were tight , but when i was checking voltage with my fluke meter some of the wires were reading battery voltage and some wires were not reading at all ? all fuses looks fine too .
  18. i disconnected the radio and still no speedo . what else should i do ?
  19. i followed the the diagram that u sent or someone sent me i forgot , i know i screwed up somewhere ? is there a wire that sends volatge up to the speedometer ? maybe my speedo just went bad ??? how can i check this ? thanks for your help Does everything else on the cluster work? Digital speed and analog speed (needle) are both out? everything i think works except the speed and odometer
  20. i followed the the diagram that u sent or someone sent me i forgot , i know i screwed up somewhere ? is there a wire that sends volatge up to the speedometer ? maybe my speedo just went bad ??? how can i check this ? thanks for your help
  21. hi i was attempting to install a radio and now the speedo/odometer stopeed working ???? can please someone show me a wiring diagram or what color the speedo wire is to the back of the dash ? has this happened to anyone else before? thanks
  22. Speedometer signal wire is gray/pink. I am perplexed as to why a radio would need the tach wire... thanks loren is that the wire grey with pink strip on which connctor ? there are three connectors on the back of the speedometer grey green and blue? i think those are the colors not 100% sure on those colors tho
  23. hey guys im a new owner to a 01 996 turbo and need an answer . i bought a new radio and it is asking for the speedometer signal wire to the speedometer and the tachometer signal wire i need to tap into those for the radio. it has this speed dyno function on it . thanks guys and please email me the info at afm998@aol.com bernie
