manfrommars
Everything posted by manfrommars
  1. We install the clear bras in the Sacramento area and I can tell you this it is not the easiest thing to install if you have not done it before. The idea is that it is to be invisible after it is installed and if you have not done a lot of installs it is hard to make that invisible part of the bra come out. Also, yes you can most likely find kits on ebay for 25.00 bucks but you do get what you pay for. There are 3 films out there that are the best Avery, xpel and 3m if you use anything else you are just asking for trouble. Here are some of them, some films are not very strong so if you get hit by a mean nasty rock it might just go right threw the film, also the cheaper film will yellow and even though they might have a warranty on the film you will still have to remove the old stuff send it back to the company and then they might send out a new one, if they are still around. Then comes the problem of removal of the old film. If it is a cheaper film you run the risk of the adhesive lifting your clear coat right off of your paint and if that happens how much money have you saved. It is my opinion that you find an installer in your area that installs the Avery film only. It is the best and strongest film out there and with a name like Avery you know that the company is not going anywhere. Go to my site at www.marsyourcars.com and I have a link on there so you can find all the kits that they have for you vehicle. Or you can just go right to www.proformdesign.com and you can find an installer in your area. Hope this helps, feel free to contact us if you have any questions.
