Neil Perry
Everything posted by Neil Perry
  1. Wide Body cars have the extra section (metal) under the sills, narrow have a plastic section in the same place.
  2. The engine trays can be replaced without removing the engine. Only need to remove the rear bumper and heat shields.
  3. Hi
    Thanks for all the information you have offered.
    Could you please tell what else has to be removed from my 993 to access the rear engine tray?
  4. Thanks for all the information. You have stated that you have removed the rear engine tray. Can you "please" tell me what other parts had to be remove from the 993 to remove the rear engine tray?
  5. The reason I thought there was need to remove the engine, as the engine shop that removed the engine before, said that the engine had to be removed to replace the engine trays, and this was Porsche. Maybe they want the work and can charge more if they say the engine needs to be removed. I will replace the engine trays myself. To do the rear engine tray, did you have to remove the rear bumper, rear heat shield and exhaust system? or what parts are needed to be removed ?
  6. Thanks for the rep[ly. To do the rear engine tray, did you have to remove the rear bumper, rear heat shield and exhaust system? or what parts are needed to be removed ? The engine was removed about 6 months ago to fix a few things, but the engine trays where not replaced. I entered the car in a concourse last week end and the judge commented that the engine trays where damaged, so I wanted to replace them, but not remove the engine again. I appreciate your feedback
  7. Please see attached jep image, rear and right side trays noted
  8. I am refering to the rear and right side engine trays that are around the engine at the lowest point, but in the engine compartment. What has to be removed to replace these two trays? I could send you a photo, if the explaniation is still not clear.
  9. Hi Has anyone replaced the engine trays in a 993 manual coupe, with engine still installed? The trays are the internal back tray Part No. 993 106 214 06 and the right tray 993 106 289 10? As the tray in my car are damaged and it seems lihe too much troubl to remove the engine for such a little issue.
