Halvin
Everything posted by Halvin
  1. When I replaced the spark plugs on my 99/996, I shortened a hex head/allen head to remove the top hex bolt on the coil packs, the allen rench ended up looking like a small L. For me removing the coils was the worst part of the job.
  2. Thanks for the post on coolant tank replacement, I am about to replace my tank in 99-996. I was wondering if you just lossened the nut on the motor mt. and let the engine down, or removed the nut completely? and where did you drain the coolant? Thanks
  3. HellO all: Can the coil packs be tested? Or do you just replace them? Thanks Hal
  4. Thats a great looking cab, better than most I have seen!! Halvin
  5. Hello: I just bought this 99 c4 and some one has put in the wronge coolent and I need to flush and change, is there a link for instructions on diy? Thanks in advance
  6. would you post the links, I have the same problem with my right window, in my 99 carrera. thanks Halvin Halvin: Here is the link for door panel removal for a 996: http://www.renntech.org/forums/index.php?s...mp;#entry116498 If I locate the other one that deals with the window regulator itself, I'll post it here, but it is pretty straightforward. Regards, Maurice.
  7. would you post the links, I have the same problem with my right window, in my 99 carrera. thanks Halvin Halvin: Here is the link for door panel removal for a 996: http://www.renntech.org/forums/index.php?s...mp;#entry116498 If I locate the other one that deals with the window regulator itself, I'll post it here, but it is pretty straightforward. Regards, Maurice.
  8. would you post the links, I have the same problem with my right window, in my 99 carrera. thanks Halvin Halvin: Here is the link for door panel removal for a 996: http://www.renntech.org/forums/index.php?s...mp;#entry116498 If I locate the other one that deals with the window regulator itself, I'll post it here, but it is pretty straightforward. Regards, Maurice.
  9. would you post the links, I have the same problem with my right window, in my 99 carrera. thanks Halvin
