bencomer
Everything posted by bencomer
  1. Loren, No the steering wheel has not been off of the car. Ben
  2. I have an 8059 fault code on my 2006 997S, and the airbag light is on. What does this mean?
  3. OK, thanks Joel. If your install is similar, how did you route your BTA 1500 cable from the battery compartment to the trunk? Did you find an existing grommet to go through, or did you have to drill a hole through the wall?
  4. BTW, my car is an 06 997 S cabriolet.
  5. OK, I got the BTA 1500 wirew through the firewall through the grommet on the DRIVER'S SIDE behind the battery (passenger side was too tough). Can anybody tell me the best way to get the BTA 1500 wire from the battery bay through the wall that separates the battery bay to the trunk? The rubber grommet behind the power brake assist appears to be a candidate, but this is another very tough grommet to get through. Is there an easier way?
  6. Here is a picture of the box I am referring to. Yes, Joel, it is near where the CD changer would be (if I had one). What is the purpose of this box? Before realizing that it does not easily pull out, I cut a small hole in the rubber grommet behind it, thinking that it connects the battery compartment to the trunk, with the idea that I would pass the BTA-1500 wire through this soft grommet easier than any other place. Once I cut the hole, I realized that the grommet leads to the back side of this carbon box. Once I realized that the box does not lift out after loosing the torx screws, I got nervous that I have sliced a grommet that needs an air-tight seal. I have two questions. Does the grommet connect to the back side of the box? If so, have I damaged it by cuting a small slice in the grommet? If the grommet does not connect to the back side of the box, how do I lift the box up enough to pull the BTA-1500 wire through the hole I cut to pull the wire into the trunk? Thanks for your help.
  7. I am installing a Dension Gateway 500 and a BTA 1500 in my 997 S Cabriolet. I am trying to find the best way to route the BTA
