TcomBrat
Everything posted by TcomBrat
  1. Frank Here is my post from the Cayman club website. I really think the issue was some kind of an interruption I hope you where able to solve your problem This happened to me last Sunday. I was at the mall parking lot and after locking the doors with the remote alarm started within 3 minutes or so. I unlocked the car and relocked it same thing. I started the car then turned it off same issue. I was only going to spend maybe 30 minutes at my destination and I was at a pretty good area so when this happened the third time I pressed on the lock key and unlocked the car walked away like it was locked. I was little worried but everything was ok Got home read the manual and it indicates that sometimes external signals such as radio ect can disrupt the IR signal from the key. I’m not sure if I had the radio on or maybe the navigation or something before I left the house but something disrupted the signal. I’m thinking this is an extra added security on the keys if someone is trying pick up the IR signals of the key while you are locking your car the car never really locks So anyway Solution: I read in the manual when this happens manually lock the car with the key and I think this confirms that you are opening the doors with the actual key. This resets the issue. I haven’t had any issues since Sunday. I hope this resolves everyone’s problems Thanx
  2. Did you try manually locking the car w/ the key had this issue on my Cayman S on Sun and that was the solution just manually insert the key and lock the car if this works i'll tell you the reason why you had this issues good luck
