omahaGT
Everything posted by omahaGT
  1. To completely remove the first plastic/leather piece under the cluster: 1. Pull it out 2. Seperate leather and plastic on steering column by pulling leather/plastic toward cluster.
  2. omahaGT
    LWFW
    The LWFW is awesome! I love it, and don't plan on taking it out. The only problem is this Porsche statement... Since the 911 GT3 (997) engine application is designed for the dual-mass flywheel, conversion to the single-mass flywheel results in the following problems and consequences: • The single-mass flywheel causes fluctuations and vibration in the lower rpm range, thereby reducing the smooth-running performance of the engine. • The crankshaft is subjected to one-sided loading, causing stress peaks that can result in damage to the crankshaft. • The one-sided loading of the crankshaft can cause the pulley to come loose, resulting in damage to the belt drive and engine. • Any damage relating to conversion or damage that can be attributed to conversion is not covered under warranty. Reply With Quote
  3. Will 997 adaptive sport seats transfer to a 996?
  4. Thanks for the post. I'm sorry to hear about your engine. Here is a Porsche statement regarding flywheels in the 997 GT3- The engine application is designed for the dual-mass flywheel, conversion to the single-mass flywheel results in the following problems and consequences: • The single-mass flywheel causes fluctuations and vibration in the lower rpm range, thereby reducing the smooth-running performance of the engine. • The crankshaft is subjected to one-sided loading, causing stress peaks that can result in damage to the crankshaft. • The one-sided loading of the crankshaft can cause the pulley to come loose, resulting in damage to the belt drive and engine. • Any damage relating to conversion or damage that can be attributed to conversion is not covered under warranty.
