500pro
Everything posted by 500pro
  1. Hi all, I am new to the forum, I have an 05 Cayenne S and last week the check engine light came on, I had it checked and the 2 codes that came up were P0431 and P0421, Catalytic converter slow to warm bank 1 and bank 2 respectfully. The car ran perfectly well, we therefore had the codes cleared and decided to leave it to see if the lights came back. 1 week later and the check engine light has reappeared with the same codes. Now generally when these codes appear they suggest either worn or faulty catalytic converters or exhaust leak or lambda sensors. However I find this hard to believe as the car has only done 34kmiles, also I wouldn't expect both cats to be in recording the same faults. Has anyone any ideas or come across this before? I have also read that some manufacturers have similar faults and its down to the monitoring tolerance being too stringent and they have changed there values to cure the fault via flash coding. I will welcome any suggestions. Thanks in advance.
