lclevert
About lclevert
    Madison, AL
    2005 Cayenne S
lclevert's Achievements
  1. I think you are seeing the bottom of the intake (it is black plastic also). If I remember correctly, the intake is a solid piece at the bottom and you can't see what's under it, which would be all of the coolant pipes.
  2. My coolant pipe let go on the wife Friday and she got the Low Coolant warning. Luckily she was only a couple of miles from the house cause she just drove it home. She thought that meant something was wrong with the air conditioner, so she turned the a/c off. Wow! Took everything apart and found a 2 inch long split in the big plastic coolant pipe. I have the coolant repair kit on order. Should be here on Tues. Can someone tell me the torque specs for the following: Thermostat housing plate (the part the 3 pipes attach to toward the front). Intake Manifold Thanks Skip
  3. Was the problem with the fuel filler door switch in the driver's door or the #11 solenoid in the diagram above? I have a problem with the switch intermittently working to open the fuel filler door. Thanks Skip
