emptyhead99
Everything posted by emptyhead99
  1. I'm hoping someone can help me here. My wife purchased a '99 Boxster with a Tiptronic in 2003 with about 11,500 miles on it. The car is immaculate. She drives it about 5000 miles per year with the odometer now showing about 36,400 miles. It is garaged daily – stored in the winter – very well taken care of - maintained well - washed weekly and is in like-new condition. About 2 1/2 years ago I had a problem with the engine running rough - check engine light coming on etc. - It turned out to be one of the engine coils and I had it replaced at my local Porsche dealer in Pittsburgh, Pennsylvania. The experience at my dealer was good, service was quick and the shop charge was fair @ $95.00 an hour. The car was finally paid off this past August and my wife was happy to get rid of a car payment after 5 years. Around the end of October she was driving the vehicle and noticed that the check engine light came on - flashed a few times and then it began running rough. I had her drive the car home and I drove it around to see how it was running - I had a feeling that it was experiencing the same problem as before with the coil, so I scheduled an appointment and took it to the dealer for service. I received a call late in the morning from the dealer that the remaining 5 engine coils should be replaced as they all had cracks in them and one had failed completely. After doing some research and speaking to a few people regarding this, I found out that this is a fairly common issue with this engine. I thought it was a little extreme and even though there are only 36,400 miles on it, I figured the car was about 10 years old, maybe it was time. I authorized the work to be done for the replacement of the 5 coils. Cost - $734.00. I received another call later in the day with some rather disturbing news. While the coils were being replaced, a compression test was done on each cylinder and the following was noted: 5 of the 6 cylinders registered a healthy 170 PSI; however 1 cylinder (#2) only registered a poor 25 PSI. Knowing that this is a fairly significant problem, I agreed with the service manager that this issue should be addressed. We both figured it would take about 1 hour to pull the valve cover and check to see if there was a stuck valve or some other problem. I authorized the service to proceed. About an hour after my conversation with the service manager I received another disturbing call. According to him, the only way to remove the valve cover was to completely remove the engine and transmission from the car, and put it on a bench for service. Huh?????? He also informed me that the shop time for this service is about 12 hours. That’s 12 hours just to remove the engine and reinstall it. 12 hours. That equates to about $1200.00. This doesn’t even count the time involved in determining what the actual problem with the engine is. I figured I could potentially be looking at another $400.00-$500.00 in shop time and parts on top of the $1200.00 before the problem is fixed. After verifying from some other dealers that this information is correct, I authorized the work to proceed. I was curious as to why a company as world renowned as Porsche have such a major design flaw as to need to completely remove an engine just to get a valve cover off? It certainly lessens my confidence in Porsche overall. I’ve always been treated right by my dealer, but I found it rather strange that the engine coils, compression issue and engine removal all seemed to happen at the same time. The dealer was rather busy with some other projects and since it's winter time, there was no rush and they would start on it when time permitted. Today I received the most disturbing call of all - according to the service manager, the engine is in pretty bad shape - apparently a small piece of the intake valve in cylinder number 2 had broken off and did a hell of a job inside the cylinder - scoring the walls, damaging the top of the piston but not putting a hole in it, damaging the rings and the inside of the cylinder head. I was told that there is no way to repair the engine because of the nature of the damage and design of the block, and the only option is to replace the engine. ARE YOU SERIOUS????? Replace the engine??? I asked him what could have caused the damage and he told me there is no definitive answer. He said maybe it could have been from over lubrication or something else - he wasn't really sure. After asking him the cost to replace the engine I had to get up off of the floor because I fell out of my chair. Cost of a new engine from Porsche.....$10,000.00. Yes that's correct - ten thousand dollars. So now I have a car worth maybe $18,000-$20,000 with an engine that's gonna cost $10K to fix - now you see my situation. He said a used engine or a new short block may come in around $6000.00 but that's still a lot of money to drop on this. I'm wondering if the valve was faulty all of these years. Maybe it had a hairline crack in it and finally let loose. Who knows? Does anyone have any suggestions? - is there any chance that Porsche would back this up if it was a faulty valve? I know the car is well out of warranty, but again, only 36,400 miles and very well taken care of. Could the cylinder be bored out and fitted with a new piston and rings? If anyone can shed some light on this it would be much appreciated as we have some difficult decisions to make. Thanks, Mark
