althoffk
Everything posted by althoffk
  1. Hi there, need help with the code. This is the serial of my radio: Y5036557 model: cdr-220 Thank you!
  2. Please help, CDR 220 BE 4462 SERIAL : Y5034914 Thank you!
  3. perfect!
  4. Hello Loren, I lost my code, thank you for your help: CDR-220 BE-4462 Serial: Y5051025 Thank you!
  5. Hello Loren, you have helped me before. This time is for a CR220 (no CD), which I plan to install on my daughter's car and hook up an IPOD. CR220 Model: BE 4362 Serial: X501 7871 Thank you, Klaus
  6. This is a different radio than the one you requested in Feb 2009? Yes Sir. I have purchased 2 used radios, this one already in hand, another one coming soon (don't have serial yet). These are purchased from EBAY, I can point to the auction if you would like. They are for 2 buddies of mine. Klaus Try 1491 or 1489 FOLLOWUP: 1493 works
  7. Try 8655 or 8653 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Hello Loren, Unfortunately I have not yet been able to activate. I have read your FAQ and I understand the odds of not being successful. One point I noticed: Using the TP function the device type shows BE4462 (NOT 6625 as on outside label) Would type 4462 yield a different code for Serial 25013769 ? Thank you, Klaus No, the code is based on the serial number. So if you gave me the correct serial number - then you have my best guess. OK, I understand, Thank you for your help, I will keep trying some other combinations. Klaus FOLLOWUP: 8765 works
  8. Try 8655 or 8653 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Hello Loren, Unfortunately I have not yet been able to activate. I have read your FAQ and I understand the odds of not being successful. One point I noticed: Using the TP function the device type shows BE4462 (NOT 6625 as on outside label) Would type 4462 yield a different code for Serial 25013769 ? Thank you, Klaus No, the code is based on the serial number. So if you gave me the correct serial number - then you have my best guess. OK, I understand, Thank you for your help, I will keep trying some other combinations. Klaus
  9. Try 8655 or 8653 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Hello Loren, Unfortunately I have not yet been able to activate. I have read your FAQ and I understand the odds of not being successful. One point I noticed: Using the TP function the device type shows BE4462 (NOT 6625 as on outside label) Would type 4462 yield a different code for Serial 25013769 ? Thank you, Klaus
  10. Hello Loren, I am hoping on receiving your help for code of the following unit: CDR220 Type BE6625 Serial 25013769 Thank you !! Klaus
  11. This is a different radio than the one you requested in Feb 2009? Yes Sir. I have purchased 2 used radios, this one already in hand, another one coming soon (don't have serial yet). These are purchased from EBAY, I can point to the auction if you would like. They are for 2 buddies of mine. Klaus Try 1491 or 1489 Thank you Loren ! Second unit arrived today, CDR220, type BE 6625, Serial 25013769 This one was purchased from CANADA, don't know if this is a factor for you, Thank you again !! Klaus
  12. This is a different radio than the one you requested in Feb 2009? Yes Sir. I have purchased 2 used radios, this one already in hand, another one coming soon (don't have serial yet). These are purchased from EBAY, I can point to the auction if you would like. They are for 2 buddies of mine. Klaus
  13. Code needed for CDR220 Type: BE 6625 Serial: 15006014 Thank you !
  14. I have a CDR220 Model: BE 4462 Serial: Y504 3511 Thank you !
