lovesolar
Everything posted by lovesolar
  1. Thank you loren Ive already did some search here, found all are very helpfull ! I have changed oil and plugs before based on peoples instructions here. Just want to make sure its a bad pipe, then i can follow the instrcution here to replace it without giving lots $ to the dealer.
  2. car: 04 Cayenne S with 110K/km it just happed suddently today on hwy, the "check coolant level" warning is on while driving on hwy, i looked at oil tem and water tem, they are right in the middle as usual, then i drove about 10min to a Mr.Lube the reservor is empty already, i can see coolant driping from the under panel, and wind blowed them all over, they refilled to the max level, then i drove about 15min back to home. I throught it was the radiator, but i smell burned coolant, and driping seems stoped or slower when i shut the car off could it be the hose ? or water pump ? could the engine alreday been damaged ? Thanks!
