livoss
Everything posted by livoss
  1. i start my engine begin to drive and there is some automatic brake on the front wheel (like if the abs activated ) then the abs light on the computer say abs default intervention after that the PSM light go on too and after that the gps is freeze at the last position before the too light go on if i stop and restart the engine the gps is ok until the too light come back all the other fonction of the pcm are ok tank you for your help my porsche dealer think it s an abs pcm sensor on a wheel ( after first thinking it was a battery default ) i think he doesn t know tank you for your help
  2. hi everybody , i m new on this forum i ve a Cayenne S 2004 since one month i ve got a problem with it sometime i start engine and when i start running there is the abs light that going on with automatic brake on the front wheel after that the psm light go on too and the automatic brake stop and the car then run perfect BUT the GPS is static after the two light go on the GPS since one month the gps going crazy sometime when i go forward the gps reverse like i run with the front of the car behind sometime everithing ok and sometime abs psm light and gpd failure (reverse or totaly freeze ) the dealer change the battery but it didn t change a thing if someone have any idea of what going wrong it will be very nice ps ; sorry for my english
