luisjara986
About luisjara986
  • Birthday 09/21/1984
    Los Angeles, CA
    2002 Boxster 2.7L
    1984 BMW 325
luisjara986's Achievements
  1. Try 7713 or 7711 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Hi Loren, Thanks for the codes however I did not have any luck with them. I tried 7709, 7711,7713, 7715, 7717and 7719. Currently wainting for my hour to pass to try again. Any other suggestions appreciated? Thanks and best regards McBee On my radio, becker cdr-220 I found that if you turn your radio off then on after two attempts it will let you try two more as long as you dont try and fail on the third attempt. When the radio turns on it will only display wait message for about a minute and then will allow you to enter the code. Hope this helps on that hour wait. :lightbulb:
  2. Try 7020 or 7018 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Thank you loren. Ill try it as soon as i get a chance and update the post. Thank you once again. 7018 and 7020 did not work, i did try ±3 with no luck. I noticed that if i turn the radio off and then on after TWO failed attempts, one is able to try two times as long as you don't enter the third time and fail. The radio will display the "wait" message but it only displays for about one minute. Since i figured that out and didn't have to wait one hour I randomly entered the code 7029 and my radio worked. Thanks a lot, hope this helps save you guys some time. :renntech:
  3. Try 7020 or 7018 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Thank you loren. Ill try it as soon as i get a chance and update the post.
  4. I would like to request a radio code for my 02 Boxster 2.7L, I just changed the battery and am locked out of my sound system. Becker CDR-220 Type: BE 4362 S/N: 25006415 Thanks, much appreciated. Luis
