MyBlue01
    2001, Boxster 2.7
MyBlue01's Achievements
  1. Try 5441 or 5439 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Thanks for the quick reply. Neither number worked so I went up 2 numbers to 5443. Still didn't work so I locked out for an hour. If the radio is a CD-220 and not a CDR-220 would that make any differance? Once I am alowed back in I plan on dropping down 2 numbers unless you have some other suggestion. Thank you, Hal CD or CDR makes no difference. Thanks again Loren. I'll give the lower number a go shortly. I tried going up and down by two and no luck. Any other suggestions? PLEASE READ the FAQ. Loren, I got my local dealer to look it up. Cost me a few bucks but oh well. The code is 6543 for your info. Thanks again for the help. Love this site by the way.
  2. Try 5441 or 5439 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Thanks for the quick reply. Neither number worked so I went up 2 numbers to 5443. Still didn't work so I locked out for an hour. If the radio is a CD-220 and not a CDR-220 would that make any differance? Once I am alowed back in I plan on dropping down 2 numbers unless you have some other suggestion. Thank you, Hal CD or CDR makes no difference. Thanks again Loren. I'll give the lower number a go shortly. I tried going up and down by two and no luck. Any other suggestions?
  3. Try 5441 or 5439 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Thanks for the quick reply. Neither number worked so I went up 2 numbers to 5443. Still didn't work so I locked out for an hour. If the radio is a CD-220 and not a CDR-220 would that make any differance? Once I am alowed back in I plan on dropping down 2 numbers unless you have some other suggestion. Thank you, Hal CD or CDR makes no difference. Thanks again Loren. I'll give the lower number a go shortly. I tried going up and down by two and no luck. Any other suggestions?
  4. Try 5441 or 5439 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Thanks for the quick reply. Neither number worked so I went up 2 numbers to 5443. Still didn't work so I locked out for an hour. If the radio is a CD-220 and not a CDR-220 would that make any differance? Once I am alowed back in I plan on dropping down 2 numbers unless you have some other suggestion. Thank you, Hal CD or CDR makes no difference. Thanks again Loren. I'll give the lower number a go shortly. I tried going up and down by two and no luck. Any other suggestions?
  5. Try 5441 or 5439 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Thanks for the quick reply. Neither number worked so I went up 2 numbers to 5443. Still didn't work so I locked out for an hour. If the radio is a CD-220 and not a CDR-220 would that make any differance? Once I am alowed back in I plan on dropping down 2 numbers unless you have some other suggestion. Thank you, Hal CD or CDR makes no difference. Thanks again Loren. I'll give the lower number a go shortly.
  6. Try 5441 or 5439 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Thanks for the quick reply. Neither number worked so I went up 2 numbers to 5443. Still didn't work so I locked out for an hour. If the radio is a CD-220 and not a CDR-220 would that make any differance? Once I am alowed back in I plan on dropping down 2 numbers unless you have some other suggestion. Thank you, Hal
  7. I am having a tough time trying to figure out how this forum posting works. I have tried several differant things and I hope I'm not just making a mess of things. Be that as it may, I am just looking for some help with my radio code. Here is what I have. 2001 Boxster CDR-220 Becker 1 Type 4462 24/99 15085036 Please help me. Thank you
