- Paint Codes
57 -
Last visited
Exterior Paint Colors
Classifieds
Everything posted by Dwiggy
99 996 AC Noise
Dwiggy replied to Dwiggy's topic in 996 Series (Carrera, Carrera 4, Carrera 4S, Targa)
Sorry about reviving the dead on this one people. The system had too much freon. That was it! -
99 996 AC Noise
Bump -
Hi all, I have a 99 C2 that buzzes very loudly on occasion. I pulled the plastic covers off of the battery compartment on a very hot day and found that the high pressure line was vibrating when the noise occured. I put the AC gauges on and discovered that the high side pressure was extremely high (>350). The AC seems to work perfectly otherwise. Has anyone else had this problem? Is this a common problem on 996's?
996 LED Install
Let us know if you purchase them. From Superbrightleds.com the 1156 and 1157 LEDs are not near as bright as the OEM bulbs. The peanut sized bulbs are just as bright if not brighter. Also, from what I have read about the V LEDs thier 1157s are actually isolated circuits. They have multiple color LEDs for turn and tail light applications. All in all the V LEDs look to be the way to go but at a premium price. D. -
996 LED Install
That would work really well on AC... ;) D. It also works well to make the LED bulb non-polarity sensitive, as in the above case. Thanks for the update W. :) I thought that a rectifier bridge was used to change AC to DC by stripping off half of the wave... but I guess what you are saying does make sense even though I wish I knew where to shop for the right LEDs. I figured they were all made the same. When I spoke to superbrightleds about this problem they did not have a solution and did not know of the issue entirely. Maybe I bought cheap 1157 LEDs as I found mine on eBay... In either case if it is not too much trouble can you send a schematic for a full wave bridge rectifier that you describe. I am somewhat familiar with circuitry but I need a visual to understand it entirely. I would like to compare your schematic to the actual 1157 LED schematics for future reference. Thanks again, D. V-LEDs on ebay. Thanks I checked out V_LEDs and they make a premium product, deffinately the way to go but very costly. They're 1157s are actually electrically isolated. I did some researching and it looks like the bridge rectifier is actually used to direct current in one way so the bulb is not polarity sensitive. D. -
X11 adn X12 connector location
Thanks again Loren. I'll check it out this weekend. D. -
Thanks Loren. On the connector sheet its in the door grid (d7, k7). Does this mean that the wires connect to the speakers and then plug into another connector in the door? Aren't there connectors under the dash. D. :huh: -
Cylinder 2 - broken wall ?
Dwiggy replied to paas's topic in 996 Series (Carrera, Carrera 4, Carrera 4S, Targa)
If 2001 seemed to be the year with the most cracked cylinders, this post brings up a very good question. Does anyone have a list of catastrophic failure causes according to model/production year? For example, my98 996's could be known for RMS failure or maybe my99 996's are known for IMS but not D-chunk. Research as this could be useful to those of us who primarily find holistic views of 996 catastrophic engine failure rates; as well as offer peace of mind. :huh::rolleyes: Thanks, D. -
996 LED Install
No problem on the 996 I'm sure the 997 is just as easy... I bought a ten pack of xenon colored WLEDs for 10 dollars off of eBay and then started plugging them into everything! :D Thanks for the compliments :) This forum stuff is fun. D. -
996 LED Install
That would work really well on AC... ;) D. It also works well to make the LED bulb non-polarity sensitive, as in the above case. Thanks for the update W. :) I thought that a rectifier bridge was used to change AC to DC by stripping off half of the wave... but I guess what you are saying does make sense even though I wish I knew where to shop for the right LEDs. I figured they were all made the same. When I spoke to superbrightleds about this problem they did not have a solution and did not know of the issue entirely. Maybe I bought cheap 1157 LEDs as I found mine on eBay... In either case if it is not too much trouble can you send a schematic for a full wave bridge rectifier that you describe. I am somewhat familiar with circuitry but I need a visual to understand it entirely. I would like to compare your schematic to the actual 1157 LED schematics for future reference. Thanks again, D. -
Fun with Microfiber
When you pry it out it will come out about a quarter of an inch and then seem difficult to move from there. You could clean it, cover it with adhesive and then place the material on it where it sits or continue to remove it. It is better to remove it as you have more area to work around and you do not risk damaging or coating the leather on the knob. If you do decide to remove the piece entirely make sure not to hit yourself in the face when you pull it out of the knob. It takes a little more pressure than feels comfortable to pull the plastic cover completely out of the knob and then it will just let go on you! :o I ended up throwing the darn thing into the back seat on accident and I almost put my eye out with the screwdriver I was still holding...LOL! :unsure: I thought I should mention this for everyone’s safety. Have fun with it and let us know how it goes for you. Maybe we can start a custom shifter trend here… D. -
996 LED Install
That would work really well on AC... ;) D. -
Fun with Microfiber
Pillipj I sent you a pm. Let me know how much you want and I'll do a diy write up on it when I get the shifter. :lol: D. -
Fun with Microfiber
Very carefully... ;) It is a press fit. I had to a small mechanic's screw driver and spent about 15 minutes working it out around the edges as to not damage it. If you damage this part you are in trouble. D. -
Last night I was a little bored and since I have about eight yards of slate colored Ultrasuede left over from my custom radio bezel I decided to use some on my boring factory shifter. What do you guys think? D.
996 LED Install
Dwiggy, Can you post pics when you are done? Would like to see a picture of the lights "lit" at night. Curious as to the difference between OEM and the LED's. Thanks, GW Here are the LEDs installed. I took pictures of the tails, the parks, side markers, hazards, maps and step lights. I used a xenon color for the interior and the park lights. What you cannot see in pictures is the clarity of these lights. The interior has a nice cool look. The turns and brakes are on and off instantly. There is no delay in LEDs. D. -
996 LED Install
I apologize, I forgot about the rear fog light. Rear Fog Lamp OEM: 7506 LED: 1156 Red BA15 24-LED bulb 7.49 ea / Total You can install two of these bulbs (one on each side) but it is not necessary. The factory configuration has two sockets but there is only a bulb on the driver's side of the car. Make that new total 133.33. D. -
996 LED Install
Here is a complete parts list for the LED replacement for a 1999 - 2001 PORSCHE 911 Parking light OEM: 2825 LED: Cool White (Color optional for fun) WLED-x6 LED bulb 3.74 ea / 2 req. 7.48 Total High mount stop light OEM: 2821 LED: WLED-Red-x LED bulb .79 ea / 14 req. 11.06 Total Front side marker OEM: 2825 LED: WLED-Amber-x LED bulb .79 ea / 2 req. 1.58 Total Step/Courtesy light/ Map Lights OEM: 2825 LED: Cool White (Color optional for fun) WLED-x6 LED bulb 3.74 ea / 4 req. 14.96 Total Front turn signal OEM: 7506 LED: 1156 Amber BA15 24-LED bulb 7.49 ea / 2 req. 14.98 Total Tail light/Stop Light OEM: 7528 LED: Red 1157 BA15 24-LED bulb 7.49 ea / 2 req. 14.98 Total Back up light OEM: 7506 LED: 1156-W12 White Wide View LED bulb 6.99 ea / 2 req. 13.98 Total Rear turn signal OEM: 7507 LED: PY21W offset 24 LED (Amber) Indicator Bulbs 10.79 pair/Total (Auction) License plate OEM: 6418 LED: Cool White 3610-x4 LED Festoon bulb 2.84 ea / 2 req. 5.68 Total Dome light/Cargo Area/Under Hood OEM: 6411 LED: Cool White 4410-x9 LED Festoon bulb 4.74 ea / 3 req. 14.22 Total Tail/Stop Light Diodes 2 x 3A 1N5404 barrel diodes 1.59 ea / 2 req. 3.18 Total (Radio Shack) Turn Signal Relay LED bulb Flasher Unit CF13 GL-02 12.95 ea / Total This is a total of 125.84 for all of the parts listed. If you do some shopping around you can find the small WLEDs for less in bundles and so on. Over all it is a cool upgrade with modern technology. Some things to consider are that LEDs are not as bright as conventional incandescent bulbs unless viewed directly. However, LEDs do require less current and because of this have virtually undetectable radiant heat. If one where to calculate the total current draw from the LED (v) incandescent circuits he or she would discover a significant drop in overall battery usage. Therefore all electrical circuits and components will get less wear and tear throughout the years. As a final note, the diodes selected for the 1157 install where chosen because they are large enough to use with the factory incandescent light bulbs if needed in a pinch when LED replacements are not available. When installing diodes, cover all exposed terminals and attempt to seal them from submersion. Do not cover the complete body of the epoxy diode as some minor heat dispersion will ensure a component longevity. References www.radioshack.com www.eBay.com www.superbrightleds.com * Most of the listed prices are from superbrightleds.com. This post may not be misconstrued as an advertisement for eBay Motors, Radio Shack or Super Bright LEDs. This poster is in no way affiliated with any of the parts vendors referenced in this forum. Finally by posting this discussion, I am by no means responsible for how viewers use this content. -
996 LED Install
In addition to the 1157 delima there is one more note I should add. If you are not familiar with LED turn signal installations this is a must read. The factory turn signal flasher requires a certain load to operate at normal timing. LEDs require about a 10th of the current that OEM bulbs require and this causes your lights to flash as if a bulb were out (rapidly). It is very simple to fix this problem by simply replacing the factory relay with an LED relay. Here is a picture of the parts required for the turnsignal instal. Take note that the rear bulbs are 7507s while the fronts are 7506s. It is easy to find the amber 7506 bulbs as they are a standard 1156 single element replacement. However, not all suppliers have the 7507 LEDs which have a different bayonet connector. I also attached a picture of my OEM rear turn signal bulb with the orange paint falling off. -
After a long decision to change all of my factory lights out with LEDs I came across a small dilemma. The tail and brake lights share an 1157 dual filament bulb. When installing the 1157 bulb the tail and brake lights would not work independently. I pulled out my multi meter and discovered that all of the light circuits in the Porsche are negative reference. Effectively this means that when a light is turned off its positive lead returns to ground. On 1157 LEDs the two stage brightness is accomplished through two series of resistors attached to the same circuit of LEDs. When 12v is connected to one lead the light is brighter then the other lead, however they are interconnected. When the tail light is turned on a 12v signal is sent to one of the 1157 leads (for low intensity). However if the brake is not depressed, the other lead (for high intensity) is grounded as well. The grounded lead negates the circuit and the light will not operate. There is a solution through the use of two more diodes. I have attached pictures to visually explain the install process. As a final note, the diodes are directional, make sure to install them with the silver stripe towards the socket as I have. D.
996 v 997 doors
997 doors are different from 996. It appears that the once the 997 factory fenders are mounted on a 996 there is still a one inch wide gap at the bottom of the meeting point. It would be nice if someone made a light weight fiberglass fender to house 997 lights in a 996 that did not require a different hood or bumper. I imagine it will look very similar to a 993. D. -
Are the 996 and 997 doors interchangeable? Does anyone have mounting pictures of the 997 door panels? Thanks, D.
Porsche 996 Fuel System Components
Pressures for the MY99: Nominal test values: Stationary engine 3.8 ±0.2 bar Engine idling 3.3 ±0.2 bar 1 BAR = 14.504 PSI at 0 FT above Sea Level -- 3.3* 14.504 = 47.862 PSI at 0 FT above Sea Level The supplied fuel quantity is 850 cc / 30 seconds total. 850 * 2*60/1000= 102 lph Fuel pump roughly equals 102 lph at 50 psi. Anyone know the injectors? Thanks, D. -
I believe this is the DME 5.2.2 can anyone confirm because pin 58 has me a little confused. 1 - Heating of HO2S after TWC 2 - Idle air control valve, closing coil 3 - Fuel injector, cylinder 1 4 - Fuel injector, cylinder 2 5 - Fuel injector, cylinder 3 6 - Ground point 9 7 - EVAP canister shutoff valve 8 - Check Engine MIL 9 - not assigned 10 - not assigned 11 - not assigned 12 - Crash signal (airbag) 13 - knock sensor 1 (cyl. 1-3) 14 - Medium pressure switch (A/C) 15 - Intake air temperature sensor 16 - Engine compartment temperature sensor 17 - Signal, mass air flow sensor 18 - Signal, H02S 2 ahead of TWC 19 - Signal, HO2S 1 ahead of TWC 20 - Ground, speed sender 21 - Signal, camshaft position sensor 1 + 2 22 - Ignition coil, cyl. 4 terminal 1 23 - Ignition coil, cyl. 3 terminal 1 24 - Ignition coil, cyl. 5 terminal 1 25 - Camshaft adjustment, bank 2 26 - Terminal 30 27 - Triggering of DME relay, terminal 85 28 - Ground, electronic system (shield) 29 - Idle air control valve opening coil 30 - Heating of HO2S ahead of TWC 31 - Fuel injector, cylinder 6 32 - Fuel injector, cylinder 4 33 - Fuel injector, cylinder 5 34 - Ground, sender 35 - Coolant fan, stage 1 36 - Coolant fan, stage 2 37 - Triggering of relay (terminal 85), secondary air pump 38 - Version coding (ground for Tiptronic) 39 - Fuel reserve pilot light 40 - not assigned 41 - Knock sensor 2 (cyl. 4-6) 42 - Automatic I/M test 43 - not assigned 44 - Signal, throttle position sensor 45 - Ground, mass air flow sensor 46 - Ground, oxygen sensors 47 - 5-volt supply for mass air flow sensor 48 - Nominal engine torque to TC control module 49 - Ignition coil, cyl. 1 terminal 1 50 - Ignition coil, cyl. 6 terminal 1 51 - Ignition coil, cyl. 2 terminal 1 52 - Camshaft adjustment, bank 1 53 - 5-volt supply, throttle position sensor 54 - Voltage supply for various components 55 - Ground, ignition 56 - Terminal 15 57 - not assigned 58 - Actual engine torque from TC control module 59 - Tuning flap (intake manifold switchover) 60 - Programming voltage 61 - EVAP canister purge valve 62 - A/C compressor On 63 - Triggering of fuel pump relay (terminal 85) 64 - not assigned 65 - Relay of engine compartment purge fan (terminal 85) 66 - Start-inhibit relay (terminal 85) 67 - not assigned 68 - Position switch/clutch switch 69 - A/C compressor requirement 70 - not assigned 71 - Ground, knock sensors 72 - Tank pressure sensor 73 - Oil temperature sensor 74 - Engine coolant temperature sensor 75 - not assigned 76 - Signal, H025 2 after TWC 77 - Signal, H025 1 after TWC 78 - Signal, rpm crankshaft position sensor 79 - Speed signal from ABS control module 80 - Speed signal output 81 - not assigned 82 - Coolant level 83 - Fuel gauge 84 - not assigned 85 - CAN low 86 - CAN high 87 - L wire 88 - K wire Thanks, D.
