Demiano
Everything posted by Demiano
  1. Copule you send me a TSB for installing interior rear dimming mirror...? To: esmerillo@yahoo.es Thanks you vera much
  2. I tried with a cigarette lighter plug-in battery, but don´t works
  3. To the Renntech forum: My 1998 Boxster, buyed in EEUU, Since it sat and the engine was not started at all, the battery drained completely. Luckily, the door could be opened with the key. I tried to open the front hood to access the battery and that’s when I found that the electronic switch, next to the driver seat, was not operating to release the hood latch. Can someone suggest a solution? I have read my owners manual, that shows you how to apply power to the fuse box so that you can open up the front hood, but My Boxster haven´t Can somen one help me Thanks
  4. One question. This kit is valid to a 986 of 1998 with pcm installed. Because I see in the diy That there is to cut some pieces, but in models with pcm haven´t it ?¿?¿
  5. I ´m going to add it. I have all the pieces but I haven´t electrical wiring for the washerlights pump I only need this
  6. my98_headlight_washers.pdf Thanks I have all those parts But, I need the electricall wiring for a washerlights pump, wire and conector to washer pump Can U help me?
  7. Its for a 1998 Boxster with litronic and washerlights Sorry
  8. Can Anyone tell me Wich part number are the complete wiring and conector for a litronic washer pump? Its for a 1998 Boxster with litronic and washerlights Thank you very much
  9. Coul anybody help me with the wirinf for OBC Hack I have purchased the parts 4 stalk and Vw Wires, nut...?¿ I don´t know exactly where I shlud conect the individual wires for correcly function...??? Thank you very much Pd: Is for a 1998 986 Boxster
  10. Exactly We can read in the PET Parts Manual this: 1 x - 1020 MM 1 x - 170 MM 1 x - 930 MM What kind of lines is apropiate...? Do you know a website where Could I order on-line?¿?¿ Thank you
  11. Hello Anybody knows where Could I buy washer lines for headlight nozzle...? Why on parts manual they haven´t part number..... Thank you Pd: And electronic leveling and control unit with wiring..?
  12. Mybe this ones http://cgi.ebay.es/ws/eBayISAPI.dll?ViewIt...9#ht_758wt_1167
  13. Hello Someguy could tell me, where Can I throught audio wire to front compartmen...where is cd Charger and amplifier I need find the original hole to pass audio and power wire for a new amplifier that I put in the front compartiment in the same place that the original cd charger Thanks?¿
  14. You connect the rear speakers directly to the AVIC HU Ok, Thanks, but, exactly where....because the rear and front output are connected to the original wire same the DY hold on here. ?¿? I was tried to connect it to a rear outoput of avic, but no function.... Only output sound by front output...that door and up board speakers Can you help me..?¿
  15. Other thing. I bought you the 986 Avic kit, but, its allo ok but I don know where I should connect the rear speakers. I tried to put with rear speakes output in avic, and no function. Where i should connect it. ?¿?¿ The door speakers and front function good
  16. Ok, and, Is possible buy you this item too?¿ http://www.euromotorspeed.com/servlet/the-...-Molding/Detail
  17. I have just buy it. I´m very happy with this matt version. Thanks
  18. Hello I would like to buy one, only the upper part. Where I could buy it? How much? Thanks
  19. Ok... Is possible connect directly to a Avic f900BT, and will be amplified by them But...other kind of conexion?¿
