Demiano
Everything posted by Demiano
  1. Depends, are you installing aftermarket amplifiers? Or using the stock? Either way, you'll have to determine if you want the rears as part of the front outputs, or the rear outputs. I used aftermarket amps since I wanted to eliminate the Nokia DSP unit (which required removing the factory 6-CH HAES amp), and changed the front dash speakers to run purely off the Front Channel Outputs (X-OVER for Mid-range 4" and Tweeters), and then for the doors and rear speakers, since I upgraded to 6.5" woofers, and 4 x 3.5" mid-range in the rear, I used an X-OVER to separate the Highs from the lows, and then ran the inputs from the X-OVER to the Outputs of the rear. In otherwords, The Front Channel is Purely the dash speakers, The Rear Channel is doors and rear speakers. Thank you very much for your answer. I have a original audio system Version M490 with original Nokia amplifier. Only I have a AVIC F900BT, the rest of audio is original
  2. Other thing Where I should connect my rear original speakers....with avic f900bt¿?¿?
  3. Other thing Where I should connect my rear original speakers....with avic f900bt¿?¿?
  4. I mounted mine up where the factory GPS antenna goes - in front of the alarm sensor and light. Pretty easy really, but you do have to cut plastic a bit to fit the wire in there (not too bad, I used a hacksaw blade in my hand). You can easily route the wire down to the back of the radio. Ok How Can I uninstall the alarma cover...?¿ Thanks
  5. Where Can I mount the GPS Antenna¿? Maybe in the same with alarm sensor...?¿ How can I unistall/install..and the wire..?
