RandalJ
Everything posted by RandalJ
  1. I posted in the Common Fixes and Repair, but onto an old thread and thought it might be better if I added a quick note here. Even if your car battery is good enough to crank your engine and start your car, if it is in old battery on the decline it will definitely shorten your remote range. In my case, it got to the point where I'd have to stand next to the driver's window, and even then it was tempermental. I did replace the battery in one of the keys to see if that was the problem, but it had no effect. After reading posts on opening the A-piller, and making the antenna the optimum length, I thought this was something I'd eventually get around to. But then, why would the range degrade if physically the antenna is the same as when the cart left the factory, and I was getting at least 30 feet when I first had the car? Last week, I had the car in for an unrelated repair, and the shop commented that the battery was weak. With most batteries that means that the battery will die within days, if not hours, here in AZ. But maybe the Optima is more forgiving because the only symptom I had experienced was slower cranking. So gradual I hardly noticed. I had installed the Optima in 2007, so it was 7 years old! Anyway, I replaced the battery right away, and my remote range went to 30+ feet (I did not test at a longer range to know just how far). So, I'm just pointing out that the antenna design, while maybe not optimal out of the factory, should work for a pretty good distance as long as your car battery is sound. And maybe the remote range is a good indicator of when it's time to start shopping for a new battery. By the way, the tester at Autozone indicated that my old battery was still good, so beware...
  2. I just wanted to pass on another tip for those who have had problems with the remote reception. Before you go to the trouble of disassembling the A-piller, have your car battery tested. Just because it cranks the car enough to start does not mean that it is 100%, and I have discovered that a new battery solved the reception problem. When I bought my 996 in 2006, the reception was fine - 30 feet if not more. I installed an Optima battery, kept the car for about four years, sold it to someone in-state, and bought it back last December (75k miles). I did notice that the key range had gotten a lot shorter, but didn't think much of it until recently, when I could be standing at the driver's window, and it would still be temperamental. I tried replacing one of the key batteries, but that didn't help. Also did a search and read up on the antenna length in the A-piller, thinking I'd get around to it... The Optima I bought in 2007 was still in the car, and by now it was 7 years old. It seemed to still crank OK, though slower than I'd like. Recently I took my car in to have the water pump replaced (preventative - slight amount of play on the shaft), and the indie shop advised that the battery was on its way out. So, off I went this morning to get a new Optima. It was at that point that it occurred to me that maybe the weakness of the car battery was causing poor reception. That maybe the system cuts power to non-essential systems if the battery is not holding charge as well as it should. Well, sure enough, I got the new battery in, and my range is back to 30 feet or so. By the way, the Autozone guy tested my old battery and pronounced it "good", so it would be best to make sure you get someone competent to test yours. If your engine cranks slowly but still enough to start the car, like mine did, that may be a clue as well.
  3. My battery was starting to go, so, inspired by another Optima DIY on Rennlist, which involved mods to the battery tray, I decided to give it a try. The other DYI involves drilling two holes through the base of the battery and through the battery tray, and bolting the battery to the tray, re-using the factory clamp on the passenger side, and re-installing the battery and tray as an assembly. I bought the Optima 34R, with reversed polarity posts because I had read that it was easier to reach with both stock battery cables. I removed the old battery, and tried to position the Optima 34R so that both cables reached. I quickly realized that that was not going to happen and still give me access to the battery tray nuts for installation. I also did not like having to remove and install the battery and tray as one assembly in the first place, if it was not necessary. So, I looked for an alternative. The Optima comes with a variety of adaptors, including a v-shaped plastic clamp. My idea was to re-use the metal factory clamp on the passenger end of the battery, and use this v-clamp on the base lip at the driver's end to snug it up. First I positioned the battery on the tray in the car to make sure the cables would reach the posts. Even with the reverse posts, it is a very tight reach. I'm wondering now whether the reverse posts buy you anything, because while the positive cable comes from the rear, the negative comes from the front. Anyway, I marked the battery tray with where the battery needed to be, prepared to replace the negative cable with a longer one if necessary. I took the battery tray out of the car, and positioned the Optima on it, the factory clamp, and the plastic adaptor clamp so that I could determine where on the tray to drill. I drilled a quarter inch hole, and started to think about the hardware. Since I would not have access to the bottom of the tray, I thought it would be best to secure a longish bolt with a washer and nut on top, so that the bolt could not turn. I went off to Ace Hardware and found a good stainless steel bolt, washer and nut, the bolt having threads all the way to the head so that the nut could be spun all the way down to clamp the bolt to the tray. Then I thought, instead of a big washer and nut to hold down the plastic adaptor, how about something you can turn by hand? So, also at Ace, I found a plastic "hand nut" (with metal threads inside). Here are some photos of the install: This shows the battery tray with the new bolt attached. Here I double check to make sure that both clamps, the factory on the right, and the plastic adaptor of the left, would fit, and that the battery would be held firmly. Finally, here is the Optima installed. The stock negative battery cable just barely made it. I had to loosen the cable at the chassis, attach at the post, then tighten the cable at the chassis again. It does not appear to be putting any undue stress on the battery. I may end up putting a washer under the hand crank. Or replacing the hand crank with a washer and bolt if it appears that the hand nut won't hold up in this environment. One other note - You can see where I had to trim away some of the plastic lip on the battery so that the "hand nut" could be turned.
  4. These rubber "accordians" can crack over time. Fortunately the rubber piece is only around $60, and can be replaced easily. You'll need to set aside about an hour and a half if you haven't done this before. Tools needed: Flat-bladed screwdriver 4mm allen wrench Ratchet with short extension and 10mm socket Parts needed: The bellows Two plastic expanding fasteners (might come with the bellows) First, deploy your spoiler manually, and shut off the ingnition. No need to disconnect the battery. You will see, along the rear edge, four caps, as seen below. These pry out easily with your fingers or with a flat bladed screwdriver. No paint to worry about, just try not to mar the plastic. With the caps off you can access the 4mm allen head bolts: I found these to be a bit tight due to exposure to the elements, but I was able to get them off with an allen key. A long allen socket would work better. Once the bolts are out, the top tray (painted part) of the spoiler can be slid toward the rear and off. Put it somewhere where it won't be scratched. Now you can see the fasteners holding the top of the bellows to the spoiler. There are two explanding plastic fasteners, one on each corner, and several sliding hooks. I destroyed my plastic fasteners since my new bellows came with new ones. Just nipped them off with wire cutters. With the two plastic fasteners off you can disengage the hooks and detach the top of the bellows by sliding it to the right, and down. The top edge of the bellows is actually sandwiched between a long metal strip and the spoiler. The metal strip has the hooks that go through pre-cut holes in the bellows. View from below: With top of bellows detached: With the top of the bellows detached, open the engine lid. You will see several circular clips holding the bottom of the bellows to the engine lid: There is one under the fan, so you will have to detach the fan. Just three 10mm bolts. Just let it hang by the cable, out of your way. Be careful not to scratch your paint while removing the clips. In my case, the clips themselves had scratched the paint a bit. Fortunately this is one of the body areas that receives only a "rough" paint job from the factory anyway. Save those clips. It is not necessary to replace them. With the clips removed, you can pull the bellows out. As with the top, there is another frame piece running the length of the bottom of the bellows. This sandwiches the bottom of the bellows to the engine lid. The bellows has pre-cut holes for the nubs on the metal strip: Lay your old bellows alongside you new one, so that you can see how the top and bottom frame strips fit. Reassembly: Transfer your frame pieces to your new bellows. Then attach bottom of bellows to engine lid with the circular clips. Push those numbs through and get those clips up as tight as possible. The idea is to clamp onto the lower bellows edge. Re-attach the fan. Close engine lid Make sure the top frame piece hooks are threaded through the top of the bellows, push up through the corresponding holes in the spoiler, and slide to the left to secure. Make sure all of the hooks are engaged and snug. Then insert and secure the two plastic expanding fasteners in the corners. This step will confirm that you have the bellows and the spoiler snug and aligned properly. Now grab your painted spoiler top, and look under it to make sure the locking tabs are lined up. Push down, and slide toward the front of the car to lock the tabs. The top and bottom of the spoiler should mate very well. If you feel gaps around any edges, check and adjust. Finally, secure the top of the spoiler with the four allen screws. Put the plastic caps on, and manually raise and lower the spoiler to make sure you haven't left any tools in there...
