big9220
Everything posted by big9220
  1. Maurice, your a legend, I will try all this asap.... and yes your right I do have the 97 RHD model... Good to know the window is not faulty. I have had some issues with the transmisions, and have recently set them all up, so maybe this is the fault.. wish me luck, just hope I can ft between the roll bars to access the motor etc, it was bad enough try to lay on the floor looking for the double relay........ I am not the smallest of guys. Ian
  2. I know this has been mentioned before, just wanted to clarify if someone can help me... Roof had been working fine, we had a large rain storm, ( england so no suprise there ) Went to operate the roof, and all I can hear is a click from the motor under the clam. I have checked the two switches under the lock near the internal mirror, and I think the switch is working fine under the hand brake, ( light comes on, and the windows come down when the hand brake is up, and unlocking the window lock. I have checked and cleaned the main large relay ( but have not tested it, I dont know how ) and as mentioned before I can hear a click when I press the up or down button on the dash..... when I do press them the lights on the dash dim a little. The car starts fine and runs fine, works from the key fob too. and the windows work ok as well..... apart from the passenger side window does not work on a one touch to close but does to open... its always been like that, I hope some one can advice, as the roof is closed I do not know if I can gain access under the clam. Ian
