boli 996
Everything posted by boli 996
  1. Anyone that have data for the DME (7.8) set points, such as the attachment (valid for C2-99). I got problem with the codes P0172 and P0175 (O2 sensing below linit) and like to check with the obd reader what all values should be. The problem have comes up 2 times (after reset) and the car ( 996 TT-03) have been driven for about 60 km every time. I have checked the system for leakage and (I hope the problem was ) the air inlet tube was a little bit out of position and also 1 screw was loose for the MAF sensor. I also like to know where the canister vacum hoses/pipe is possible to find (picture)
  2. I have found it out, it's for the exhaust system, but the equpment is not mounted......
  3. The problem is that I'm living in the northern parts of Sweden and Porsche doesn't know that Sweden is 1900 km long, on the Porsche cd it's only 700 km long and that is to the middel of Sweden
  4. Anyone that knows what normal (max) turbo pressure is for a 996 TT -03 ? The only data I have read is that the pressure variate depending on fuel quality and outside air pressure.
  5. I mean if it's possibile to by a new cd from Navtech or equal company that have more detailed data than Porsche orginal, or if the cd from a another car manufacture will work.
  6. The seat heating are placed on the right side at the midle console. The car is 996 TT-03
  7. Is possible to buy a not original Porsche navigator cd that works on PCM2 (Becker)? Addresses ?
  8. I got a 3-postion switch marked I-O-II closed in front of the buttons for the seats memory on drivers side. Any one that knows the function of this switch , the local Porsche dealer didn't have any idea and it doesn't shows in the manual.
  9. Yes it's phone in the car, and the amp nr is 996 645 245 00, I belive it's the bose system in the car
  10. I got an error message that says System error :Phone, amplifier not aviable Could that be a version fault?, If so is it possible to make a cold restart of the PCM so it's possible to hear the radio until I go to Porsche and make an update Anyone that knows how to check version of software in PCM2?
  11. Anyone that have instruction how to remove the PCM2
  12. Anyone that knows what this optioncodes is COO XSJ XSM XSX 003 424 441 567 581 695 722 990
  13. Does anyone have any experience of converting a standard 996 (-99) engine to a turbo engine. FVD have a modification package, is that a good one or ? What does the kit consist of ? I have a 996 C2-99 with X51 kit.
