eross
Everything posted by eross
  1. Thinking positively, I may have misunderstood the service rep's intent to explain that the cause of the fluid loss is unknown and the cause for replacing the clutch kit is the damaged bearing (due to the loss of fluid). I will, however, follow up and pursue additional opinions per your suggestion if clarification isn't forthcoming.
  2. Greetings, I have an '06 Manual Transmission Cayenne with 63,000 miles. I took the vehicle to the dealer when the clutch pedal suddenly lost pressure while I was driving. After checking it out, the dealer reported that all the fluid somehow escaped the clutch assembly. A worn or otherwise damaged bearing is suspected. Parts and labor will be roughly $4,000.00 to replace the entire clutch kit. Does anyone have any insights from having had a similar experience? Based on my driving history with other manual transmissions, I expected to get to at least 100,000 miles with this vehicle before replacing the clutch. Thanks in advance for your comments. -El
