a239996
Everything posted by a239996
  1. hello Loren could you send me a PM on this repair please. my email is a239996@gmail.com Albert
  2. Hello I am need of my radio code for my 2000 boxster s. Becker radio 220 model 4462 serial y5039027. thank you Albert
  3. Hello I am need of my radio code for my 2000 boxster s. Becker radio 220 model 4462 serial y5039027. thank you Albert
  4. i need to know what type of tranny fluid is used for a 3.2 6 speed manual transmission. thanks
  5. you are correct i had it serviced and it was a broken spring. My question now is could this be repaired using same clutch kit as i felt it was reusable or to replace the kit was the common sense answer
  6. What do you mean the pedal? or the clutch slave arm on the transmission? The pedal means nothing - if the slave arm on the transmission is not moving then you have a hydraulic problem. sorry, I mean the clutch pedal.
  7. interesting, the clutch has good movement back and forth would that rule out the clutch master cylinder?
  8. When you say "no tension in the pedal", did the pedal drop to the floor, or just feel generally weak? Could be a hydraulic issue. sorry, I meant generally week. there is no signs of a leak
  9. Hi it is a 2000 boxster s.driving from 2nd to 3rd noticed no tension in pedal and shift would not go into third. No previous symptoms indicating clutch about to go. Can you help diagnose. Thank you
