incubus
Everything posted by incubus
  1. Just sent my car into repairs and received a bill for a whooping $6500 wanted to run the list by you so i could identify the most critical jobs that have to be done. Issues 1) slow leak of engine oil apparently a drop every 20 minutes (as described by the serivce center) ------------------------------------------------------------- WORK TO BE DONE: Need to pull down the engine to replace tappet cover gaskets and seals behind the cooler need to cofirm what else is leaking. Engine tappet seals part cost not estimated once engine is out will inspect and inform accordingly. DESCRIPTION QTY Total Price (AED) remove engine for inspecting tappet covers 10 2,700.00 replace gear mounting 1 270.00 wheel alignment 300.00 wheel balance 200.00 replace left hand side rear axle seal 1.5 405.00 remove and install rear brake rotor disc 0.8 216.00 polishing rear brake rotor discs 120.00 replace rear spoiler mechanism 2.5 675.00 Interior painting 2,000.00 replace brake fluid 0.8 216.00 Major service - with parts 2,600.00 PARTS/MATERIALS PART NUMBER DESCRIPTION Price QTY Total Price C SHAFT SEAL 103.00 1 103.00 DRIVING MECHANISM SPOILER 5,733.00 1 5,733.00 FANFARE LOW-PITCHED 141.00 1 141.00 FANFARE HIGH-PITCHED 141.00 1 141.00 Brake Fluid 1liter 80.00 1 80.00 transmission carrier 812.00 1 812.00 Consumables 701.94 1 701.94
  2. Apologies guys its the Lamborghini Style Doors - http://www.esetuning.com/product-p/lsd-doors-porsche.htm
  3. I just got the new LSD door kits for the cab. Gonna try and install it this weekend... has anyone installed the kit earlier anything i shoudl keep in mind ?
  4. I'm wondering if anyone has tried installing the carbon fiber trim set in the porsches. its being sold on ebay http://cgi.ebay.com/ebaymotors/Porsche-996...sQ5fAccessories Carbon fiber replacement parts seem like a really expensive option...
  5. Guys Any known issues with the 2004 996 turbo cab? things to be careful of? ...critical fixes? ...etc.?
  6. First, is this a dealer? Are they using PIWIS or PST2 to reprogram? Do you trust them? To reset, put the battery in reverse polarity for 10 seconds, then install correctly. these guys are not the dealers they are Houe of Cars - http://www.houseofcarsgroup.com/shop/porsc..._specialist.php When it comes to trust.. i guess you really cant trust most of the auto garages back here... Will try the reset and revert
  7. i dont really know.. theyve tried reprogramming it and it apparently gives them an error which is why they are reccomending replacement. I tried chanign the battery adn there was no change. how can you reset it though?
  8. Hey guys Just compelted two mods on the Turbo from FVD the first was a 70HP increasing software upgrade .. wondering if anyone else has tried this and what the results have been. Software http://www.fvd.de/de/en/Porsche-0/996_Turb...astLoad%29.html and the second was a reinforced Diverter Value - (comes highly reccomended over the original) http://www.fvd.de/de/en/Porsche-0/996_Turb...nforced%29.html Looking at upgrading my exhaust http://www.fvd.de/us/en/Porsche-0/996_Turb...Cat-Bypass.html what do you guys think and any other reccomendations? Boney Varghese 2004 Turbo Cab
  9. Newbie alert... hey guys.. i seem to have a situation with my 2004 Turbo Cab. The remote key stopped working suddenly and the agency claims that the FOB is damaged and needs replcaement. The cost for a new one is around $380 but i also see new ones one the ebay for less than half that cost. The agency claims that the key needs to match your chassis numebr to work and so a regualr one wont do... is thsi true? ...or cani just go ahead and get one off ebay and have it programmed?
