eliab
About eliab
  • Birthday 09/04/1968
    Eliab Rodriguez
    POC (Porsche Owners Club)
    Boxter S 2000
eliab's Achievements
  1. Need help with my boxster S , 2000 window After a while, my window stop working, finally when i open the door assembly i found that my lowering system cable was rusted and broken, any suggestion on replacing this metal wire? do I need to buy the whole system? If so please advisae where to find it, I live in Puerto Rico and we dont have many options locally. Happy holidays
  2. They start to wear on the outside , then separate the threads, i will try to get a picture of it
  3. I need help with my 2000 986 s , Its only 35k miles on it but since i Bougth it 6 months ago i had 3 broken accesories belts. two of those were original porsche , the last one was a aftermarket replacement. I had cheked the pulleys , they seem to be ok, two months ago i replaced the alternator clutch, blaming the problem on that Any ideas? Thks Eliab Puerto Rico
  4. Try 1208 or 1206 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Wrong code maybe its not a SO its Y5034443, maybe thats why its not working Tried both and none worked, also try 1207 and 1209, also tried 1201, 1202. 1203
  5. Try 1208 or 1206 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Wrong code maybe its not a SO its Y5034443, maybe thats why its not working Tried both and none worked, also try 1207 and 1209
  6. Try 1208 or 1206 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Tried both and none worked, also try 1207 and 1209
  7. I hope this is the correct place to ask for the code Model CDR 220 Serial number YSO34443
  8. serial number its YSO34443 model cdr220
  9. It was a replacemet gates , I bougth it from pelican parts in California, shipped fed ex to Puerto Rico, I checked the pulleys and send my alternator for repairs, I will change the pulley and inside bearings as precaution. Everything else seems to be fine.
  10. thank you, I installed correctly, seems the new one came with a defect, anything that I should check, after the belt broke?
  11. Can somebody send me a detailed diagram of the belt? I installed a new one today and snap in a few minutes
  12. SOUND ITS COMING FROM ALTERNATOR, LOOKS LIKE THE BEARINGS AT THE PULLEY ARE GONE. SHOULD I REPLACE THIS ONE OR SENT IT FOR REBUILD? SHOULD I CHANGE THE TENSIONERS AT THE SAME TIME? THANK YOU FOR YOUR HELP, IM A ROOKIE WITH PORSCHES, MY DREAM CAR
  13. Any chance of doing this from the top?
  14. Thank you, will do that today
