res1afbe
Everything posted by res1afbe
  1. One reason the resonance flap isn't isn't moving could be that it's not hooked up. The original Boxster harness doesn't come wired for it, so you have to add your own harness wire (from the DME control unit to a new vacuum switch under the intake plenum.) A vacuum "T" to the vacuum switch is also required to get the system up and running, so it could very well be that the installer simply neglected to add the extra parts required to take advantage of the resonance flap on the 3.4 liter intake.
  2. has not set their status
