REDLINE WINS
Everything posted by REDLINE WINS
  1. if you replaced the battery and the remote still does not work then it is the remote...i have replaced hundreds under warranty and customer pay when i was a tech. the new remote will have to be programed to your car as well as the imobilizer pill...this can only be done with a PST2 and you will need the key learn codes from Porsche, basically it can only be done at a dealer.
  2. you can reset the CEL only if the fault is not present (soft fault) by pulling the DME fuse or disconnecting the battery. if the fault is present (hard fault) it can only be turned off by a scanner.
  3. it is very important to know if the P1128 and P1130 is above or below threshold. you cannot properly diagnose these codes without knowing and you usually will not know unless you use a PST2. in most cases with P1128 and P1130 i have found that the MAF sensor signal is faulty causing the DME to pull fuel.
  4. the third bolt is sometimes hidden behind a round sticker, the sticker covers the access hole for the bolt.
  5. noise is from the mufflers...current tech bullentin on this issue.
