GOALIE31
Everything posted by GOALIE31
  1. Fixed. The socket was not snapped in all the way on the new harness.
  2. If your Fans are working,you might try bleeding the coolant system again you could have an air pocket.
  3. How could you tell if the Evap Cannister is bad without a code?
  4. I am having a problem with the accesory litronic kit. I installed the harness and module per the TSB it worked for a while now the headlamps wont adjust when the high beem is activated.Does anyone know how to test the module? Side note my headlamp switch went bad it was stuck pulled out so the fog lights were on all the time(switch has been replaced). Thanks for the future help
