oguneri
    Northern CA
    2000 Carrera Coupe (996) Dark blue
    1998 ML320
    2008 Subaru impreza
    2005 C230 Komp
    2000 Saab 9-5 Wagon
    2001 Alfa Romeo 156 2.0 Tspark
    1996 Alfa Romeo 145 Boxer
oguneri's Achievements
  1. Thank you Dharn55, the information you provided it really helped. I think MAF change is my solution at least the first step. Cheers,
  2. Should I get with or without the E.Accelerator?..there seems to be two different kinds on net.Also would you recommend Bosch? They are aroun $2XX on net. Thank you again,
  3. Thank you Loren, I actually mentioned that I cleaned MAF and it really made the difference on power(it pulls very hard once it moves from the inital hesitancy around 2000-3500 rpm. So what would you be your next step if the MAF is cleaned? thank you again for your quick response. cheers
  4. Hello to all, I recently got a 2000 911 Carrera coupe, 6 speeds with 54k on it, and enjoying it very much. (it has in immaculate shape both in, out and engine) I had oil changed, 60k maintenance done and also had head seals fixed-(was leaking due to rarely drivind by previous owner) not too long ago. I have put more than 2k since the service done. I have been having CEL problems since last two weeks, first it was P1126 and P1133, I reset and drove 40 miles came back, than CEL turned on again for MAF sensor problem. From this forum I got to learn to clean MAF and car started to go a lot better(it feels lke 50hp was missing before). Now P1126 and P1133 came back again. Only problem that I can tell is little hesitancy between 2,000 rpm and 3,500rpm. Before I go to service, I would like to get your wise opinions. Thank you for all your time in advance. ps. I have searched this form up and down and only came accross P1126 once was never seen P1133. OGUNERI
