Vman
Everything posted by Vman
  1. New MAF in car, old stock airbox with clean filter back in, going to dyno tommorow with fingers crossed. Will deal with the throttle cable after we fix the air fuel ratio problem, thanks for the tip though Thanks, VMAN
  2. The following was taken while running stock Porsche OBD2 program, no inline tuning has been done. MAF readings at idle (between 695 to 800 rpms) with zero throttle ranges from (.59 to .84 lb./min) or (4.5 to 6.5 g/s). Porsche system tester 2 shows the MAF with no errors. Other points of reference at 98% throttle position RPM 3944, Timing -14.5, vehicle speed 125 mph, MAF (lb/min 12) RPM 4321, Timing, -21, vehicle speed 65 mph, MAF (lb/min) 8.9) RPM 5169, Timing, -34, vehicle speed 79 mph, MAF (lb/min 22.89) RPM 7020, Timing, -22.5, vehicle speed 110 mph MAF (lb/min 19.6) Any help would be great. Any idea if their is a more advanced way in the Porsche system 2 to determine if the MAF is having issues, but not showing a fault. Thanks, VMAN
  3. We tested the fuel rail pressure and fuel pump volume flow according to the factory manual. Also, the maf and 02 sensors read no fault on the porsche system 2 tester. Note - O2 readings for both before and after cat banks were over 850 mv above 4,500 rpms. Any ideas would be helpful, we are left to conclude that either we have a bad MAF that is not showing up on the tester, or the porsche ecu just can't handle the extra requirements of the K&N aircharger, racing headers, and high flow cats, in which case we will have to be looking for a piggy back system like a unichip to try and remap the fuel curve. Let me know if you guys think we are missing something, as a custom programmed unichip to pull down my airflow ratio to a safer level will set me a back about $3K. Thanks, VMAN Well, the first thing I would do it check the other tailpipe to see if it also shows bank 2 is also showing lean at WOT. If bank 2 shows proper AFR, then the problem is with bank 1, (injectors, o2 sensors or exhaust componants). If it shows the same (and it is an accurate reading), then the problem would include a componant that controls both banks, such as MAF, fuel regulator, tuning, fuel pump, vacuum leak, etc. Check what the after cat sensors show...both banks.
  4. Thanks Well, the first thing I would do it check the other tailpipe to see if it also shows bank 2 is also showing lean at WOT. If bank 2 shows proper AFR, then the problem is with bank 1, (injectors, o2 sensors or exhaust componants). If it shows the same (and it is an accurate reading), then the problem would include a componant that controls both banks, such as MAF, fuel regulator, tuning, fuel pump, vacuum leak, etc. Check what the after cat sensors show...both banks.
  5. 110 Octane is leaded only so say good bye to your cats, a mix of 104 unleaded racing fuel with pump gas 50/50 to 30/70 will get you good HP numbers. If you are set on running 110 you will need to map your car for ROW DME (it does not look for an after cat 02 sensor and buy some cat bypass pipes.
  6. Both runs were measured on separate dynos using the right tailpipe.
  7. I have a 1999 996, in the process of doing some dyno work on both Dynojet and Dyno Dynamics Dynos (load bearing), we discovered that the car was producing a max of 258 hp, but that the air/fuel ratio started at 16 and went down to 13 betwen 3,500 and 4,500 rpm, the problem is after 4,500 rpm the air/fuel ratio kept rising up to around 14.5 and no lower than 13.6. The car is running a U.S OBD 2 program with a K&N aircharger, Scargo headers, high flow cats and stock mufflers. The airfuel/ratio problem was the same with the stock airbox. We have about 300 miles driving the car since loading the US OBD 3 program. Is this a dangerously lean situation? How would you go about improving identifying the problem, as I am told your fuel air ratio should be around 13 to 13.5 to generate maximum power or this okay? If it is a problem, how should we go about fixing it? Fuel filter - has been changed Bad fuel pump relay - how do you test? Bad fuel pump - how do you test? Bad fuel sytem relay - how do you test? Bad injectors - anyway to test? Does the Swepco injector cleaner work? Note - before I purchased the car it was running on a mix of 110 leaded race gas and pump gas and had no cats, it was running the ROW DME program and producing about 275 HP on a dynojet dyno and averaging about a 13.2 air fuel ratio above 4,500 rpm...Note - the last dyno test on the car before me buying it and changing to the US DME program and adding back cats is less than 3 months old Thanks, VMAN
  8. I just had to add cats to a 1999 996 car I imported from out of state, I live in CA. The prior owner had flashed the car with the ROW factory DME program, which apparently ignores after cat O2 sensors so he could run the car with no cats. My local shop tried to flash the car back to OBD2 (I say try because I am not sure it took), while we are getting volatage values for all o2 sensors we are not getting a check engine light when we unplug the after cat 02 sensor. Does anyone have any idea on how to confirm which program you are running, in looking at porsche black box programmer laptop it shows which program you can load but does not seem to show which program is in the car. Thanks, vman
  9. I just finished installing two differentials in my 996's. First the factory limited differential is a 22(on throttle)/40 (off throttle) and needs to be rebuilt or at least checked every 50,000 miles. The Quaife is torsen sensing, so its results are said by many to be inconsistant and not really as good as a true limited slip, particularly on the track. The best maker of after market limited slip diffs is Guard Transmission, http://www.guardtransmission.com, I just bought a 40/60 Guard limited slip. The guard unit is not cheap it will cost about $2,600 then another $600 to buy 993 G50 flanges to fit in a 996, plus about 6 hours of labor (assuming you can find a shop that knows how to drop a transmission without taking out the engine). Note - factory GT3's use a 40/65 limited slip ...beware if you are going to use the car on the road as well as track to not go much more aggressive than a 40/60. Finally stay away from no name groups, there are some dirt bags out there in the tranmission arena. VMAN
  10. Any idea how to id a limited slip differential before or after cracking open a transmission. I looked up PET and it gives a number of 996 300 020 (00-02) The bottom of my tranmission says G960 020 07746. apparently the diff part says 950 332 08 301..none of which I can find in the retail version of PET. VMan
  11. Does anyone know on throttle off throttle lockup for the factory lsd on a 99 carrera C2 I have heard 25/45 and 40/60? What is the right number for what I believe to be and M220 option. thanks, Vman
  12. Thanks, I ended up using intercitylines, same deal as you got $1425 seattle to sd
  13. Guys, Just bought a new 996, this one is lowered and needs to makes its way from Seattle to San Diego. Does anyone know of a reliable company that can move the car in an enclosed trailer? Also, any tips to make sure the move does not screw up the car? Thanks, Vman
  14. confirmed the Sir Tool is no longer available, for some reaosn they discontinued it, but the nice lady on the phone said they may come out with a new tool in a couple of months. Sir Tools knew of no competing products either...so for now it is risk solder and splice or go to the dealer and get ripped off on the install. Vman
  15. I made the mistake of ordering my litronic kit and trusting the dealer that I did not need any special tools, for the install. I am halfway into install and it is obvious I need the porsche pin removal tool or a good way to get the pins out and reconnect the wiring. I would really like to wrap this thing up this weekend, so if anyone has a method that works for popping out the electric pins or a non-special order tool (one you can buy at a national store..sears, radio shack) please let me know. Thanks, VMAN
  16. Below is how the Boxster traction control system supposedly works in a 1999, does anyone know if the 996 C2 Traction control system works the same way? Option P37, Traction Control consists of two separate items, Active Brake Differential (ABD) and Anti Slip Regulation (ASR). When one of the rear wheels begins to lose traction, the ABD applies the brake to that wheel. If both wheels lose traction, the ASR reduces engine power until traction is regained. The Traction Control switch on the dash turns off the ASR, but not the ABD. The ABD is always in effect until you reach 62.5 mph, at which time it automatically deactivates. Because the ABD is always in effect and is applying braking not under your control, control freaks may not wish to order this option. In particular is ABD always on for the 996? in Autox it seems that it should not matter if you turn Trac on or off as speeds are usually under 65 mph. Has anyone tried disconnecting the system and adding in a Quaife Differential? Thanks, VMan
  17. The RoW GT3 mark I (not sold in the US) came with 8 x 18 fronts and 10 x 18 rears in MY99 to MY02. Just as today that car was the basis for the GT3 Cup and GT3R race cars. I wouldn't say much more oversteer perhaps less understeer. So no real problems in running the 7.5 and 10 wheels with a 225 front and 285 rear? Other than you may get a bit more understeer?
  18. Loren what do you mean ALA GT3...didn't the GT-3 always come with 235/295 and 8.5x 18 and 11 x 18 wheels? Also, more importantly, I assume there is nothing wrong with running 225/265 with the 8x18f, 10x18R, other than the car will have less understeer..read more likely to oversteer than a car with 285 in the rear? I am asking as I have some old 18 inch turbo twist wheels in 7.5 x18 and a second set in 8x18 and want to run one rear tire size on the car.
  19. I am heading down to Sears for the jack. On the wheel chokes, I assume you would only need them if you jack the car up from the rear without first putting the front up on jacks. When jacking the car up from the side rear jack point, (in front of the rear tire) as one half of the car is still on the ground I assume it would not be a problem. Please confirm if I am getting this wrong.
  20. The correct weight of these wheels is W=(VM-(vm-CW)). You can derive this with your bathroom scale. :eek: the wheels are already mounted with tires, I would like to know the weight without the tires...without having to unmount the tires. Anyone with an 2002 later car ...please open your owners manual and give me the weight for the wheels listed in the back, I would really appreciate it. Thanks, VM
  21. Guys, I need to do some work on the car, but before doing so need to buy the following 1) jack stands 2) Floor Jack 3) Ramps 4) torque wrench and socket that will fit standard 996 wheel bolts. Can anyone recommend high quality, but reasonably priced products and where to get them? Thanks in advance. P.S. anyone know how to change wheel lug bolts without scratching them and then having them develop a nice coat of rust? Vman
