986boxster99
Everything posted by 986boxster99
  1. Has anyone had a problem with the B3 fuse (horn) shorting continually? My horn does not work and the solution may to replace the horn ring assembly that has been discussed here. I did not want to do this if someone has had this problem and the short was in some other component. If the fix for this is to replace the horn ring assembly, then I shall do that. Someone recommended replacing the #10 relay switch and then replacing the B3 fuse. This did not make any difference, as soon as the fuse was inserted, it shorted.
