Scott in So Cal
Contact Methods
  • ICQ
  • Yahoo
    guinnesman
    2000 Boxster 2.7
Scott in So Cal's Achievements
  1. So I have a check engine light, CEL code P0446, and the car is very hard to start after filling up with gas. This has happened three times in a row so I guess it's not going away. :rolleyes: Anyway I searched the archives and found someone who was having this same problem, which was eventually fixed by replacing the EVAP canister, purge valve and vent tube. My question is, I'm wondering if all that needs to be done in unison or if I can start by replacing the EVAP canister to see if that solves the problem and then if not proceed to the other two items. The canister appears to be a DIY item (?) whereas I'm not sure about the other two. Anyone have any thoughts/advice? Thanks! 2000 Boxster 2.7 91000 miles
  2. My owners maintenance manual makes no mention of a fuel filter change at all, but isn't it supposed to be changed at 60,000 miles? I thought MY02 is when they eliminated the fuel filter change.
