AvtoWeb
Everything posted by AvtoWeb
  1. Do I need to replace the complete belts, or just the pyro tensioners alone? thnaks,-
  2. I am repairing my 2005 997, both airbags were deployed, but both front seatbelts seemed fine until I made check with Durametric. It says "both front seatbelt tensioners exceeded the upper limit" !!?? Does this mean I will have to replace both front seatbelts or is there another, cheaper way to get it done? Both seatbelts move normally in and out of their compartments. Thanks for any advice.
  3. could anyone help me sync these error codes with further repair instructions: ________________________________ Porsche Stability Management - PSM Current Fault Codes 4444: Steering-angle sensor not initialized ___________________________________ Airbag - POSIP Current Fault Codes 8023: Driver's head airbag short circuit to ground 8009: Driver's belt tensioner above upper limit Upper limit value exceeded 800A: Passenger's belt tensioner above upper limit Upper limit value exceeded __________________________________ Air Conditioning Current Fault Codes C203: Fault steering wheel electronics control unit (drive) Implausible signal _____________________________________ i tried to initialize steering sensor with durametric, but nothing really happened. thanks for your answers
