deanmck
Everything posted by deanmck
  1. //*same issue my friend. find a do it yourself article on how to bleed the air properly , you must be patient but it will work if you follow directions. Read this artlcle, at the end it tells you how to properly bleed it, http://www.pelicanpa...WATER-Flush.htm i will try this thanks. did it work for you?
  2. Also my heating isnt working now? There is cold air comming from the inside of the car? does the air bubbles contribute to this or is it a seperate issue?
  3. I have not tried that, i will try this tomorrow and let you know how i get on. Should the full 22 litres (11 water) and 11 coolant be added? As there was previous water about 4 litres in it after the water pump was replaced?
  4. Porsche Boxter 2.7 (UK) 2002 Facelift edition Water pump was burst, has now been replaced. Began refilling with Porsche engine coolant, but struggling for the coolant and water to go down the tube, keeps bubbling and pressure keeps building up with the dial on dash ticking upto 120 (Red) after about 2/3 mins of engine 3k revs. Have been told about air pockets? Told this can be a long process, but the more coolent thats put in, i would imagine the car wouldnt be overheating but still continues to go above 90 on the dash then eventually heading towards 120. Any tips on removing air pockets or any tips on how to sort the overheating please? Dean
