larrybrunswick
Everything posted by larrybrunswick
  1. I cleaned the MAF, throttle body, and replaced the air filter. the car runs a LOT better now...it is much more responsive :) My CEL came on again today after 52 miles... haven't pulled the codes yet... :(
  2. I've been getting a grinding noise on start occasionally. it only happens abt. 1 out of 15 times. it sounds like the starter isn't retracting fast enough from the flywheel . has anyone else had this problem??? please help if you can :)
  3. Thx Loren and kbrandsma, I've been checking into via websearches... My plan of attack is 1. change air filter---I've had the car for 1.5 years and put 22,000 miles on it, not sure when last replaced 2. check for vacuum leaks 3. clean MAF with MAF cleaner then..... cross my fingers and give it another try :) anything else I could-should or might do while I'm doing this?
  4. fyi...i have a 2000 boxster 2.7
  5. I had a problem with the trunk not opening with the remote... found a blown fuse in the fuse panel... the horn is also connected on the same circuit if i remember correctly... so if ur horn doesnt work as welll...that may be the problem
  6. I have a check engine light on and checked the p-codes at autozone. P 1126 and p1133 came up... my car has been running like this for over a year (I know-- I should've checked into it earlier), but I'm finally getting down the the solution...hopefully. Does anyone having experience with the aforementioned problems... I would love some input :) Thx
