Click here to Donate
RIC480
  • Content Count
    32
Everything posted by RIC480
  1. 2013 Carrera 911 4S Inside door panel separating from door frame . Is this happening to anyone ?
  2. 2013 Carrera 911 S4 Navigation on However not talking (no sound) when I'm on my Bluetooth phone Samsung S8 Works fine when not on my phone Can any one help ??
  3. Now i am planning to drive from Florida to New York, 2 days 12 hours per day and what ever speed I can get it up to without getting caught . My question is should I make any adjustment to tire pressure ? I'm set on COMFORT PRESSURE THANKS
  4. 2013 Carrera 911 S4 991 What is the correct tire pressure ? The. manual is lower than whats on the car label in the door jam ?? Thanks
  5. Hi I'm looking for a bra to protect the front of my car (not clear type) . Does porsche make one ? Or does anyone know where i can purchase one .Must protect bumper and a good portion of the hood. Thanks
  6. I got it thanks But I live in florida Also for $125,000 don't you think they should get it right !
  7. 2013 991 4s Backing up turning the wheel all the way to the right or left its like the front wheel is hitting against something.or going over somethimg .Any ideas ?
  8. Have you got any codes? Have you had any maintenance or disconnected the battery? Changed a tire? When the power supply is disconnected (terminal 30), the built−in GPS receiver loses the so−called almanac! The almanac stores the satellite orbits and ensures fast location of the individual satellites when the system is started. Procedure after changing a tire: Drive on a motorway if possible at a speed greater than 60 km/h for a distance of approx. 50 km (calibration of the distance measurement). Procedure after the power supply has been interrupted: Procedure after the power
  9. Have you got any codes? Have you had any maintenance or disconnected the battery? Changed a tire? When the power supply is disconnected (terminal 30), the built−in GPS receiver loses the so−called almanac! The almanac stores the satellite orbits and ensures fast location of the individual satellites when the system is started. Procedure after changing a tire: Drive on a motorway if possible at a speed greater than 60 km/h for a distance of approx. 50 km (calibration of the distance measurement). Procedure after the power supply has been interrupted: Procedure after the power
  10. Hi-- 2004 911 anv. Navigation is out of wack -Doesn't know where I am. Any reset???
  11. Yes! -Maybe fuel injector ???? No, I don't mean fuel injector I mean bad gas. Highly unlikely that all 6 injectors would be bad. Loren -Good call -Filled up fresh gas diffrent station --Problem solved -Your were correct Thanks Again Rick :)
  12. Yes! -Maybe fuel injector ???? No, I don't mean fuel injector I mean bad gas. Highly unlikely that all 6 injectors would be bad. Would'nt I feel it when driving ????????
  13. Unfortunately when you say the battery is 1 year old doesn't mean much (in terms of manufacture). Do you keep it on a maintainer? If not, it would be my first suspect as well. Just pluged into today -I'll see what happens tomorrow :o
  14. battery would be my guess. Thanks --But the battery is less than 1 year --Battery sounds strong :(
  15. Hi--My 2004 911 Annv. parked in garage - The last 2 days in the morning only it now takes 2 trys to start up .Before it allways started on frist try. Whats happen ??? :huh:
  16. Hi-- 2004 911 Aniv with 20000 mile .Does any one know the life span on brakes. My dealer has a special this month -25% off parts and labor Thank Rick
  17. Hi - Went to the dealer and purchased the new 8 disks part # 000-044-901-21 for my 2004 996 aniv . I have PCM software version 3.0. The dealer charged 299.00 for disks and 135.00 for installation. When I asked what installation ,he said the system needed to be updated so the new disks will work and the older disks would not work anymore . Did I get taken for 135.00 ???????? Thanks Rick <_<.
  18. Hi - I have a 2004 911 anniversary-Does any one know the clearence between the clutch and floor board when starting and shfting??
  19. Are both lights on and you get a display message? or just both lights? Yes both lights are on and display message "psm not working drve to workshop"
  20. How old is your battery?? If your battery is original, this may be the symptoms of the battery getting close to end of usable life. If you don't drive the car daily, do you sue a battey maintainer?? If you have a shop voltmeter, check the battery voltage at the terminals before you drive the car after sitting since lat drive. Should be at least 12.5 volts ( optimum would be 13+). If less, battery may be on last legs demosan Yes its original battery.No I don't drive much I bought the car after one year with 7300 miles now its 4 years old and I have 16.000 miles.Took volt test after car
  21. HI I started up my 2004 911 anniv. I got this warning "PCM Not working drive to workshop" also ABS light flashing.Turned off engine and restarted. all fine . Next day started up again all fine. My warrantty is over in 20 days <_< Thanks Concerned
