expoman55
Everything posted by expoman55
  1. Maybe obvious, but have you checked the fuse panel? There is a fuse that controls each seat operation? Worth checking? However, if it clicks (not from button moving, but from power) maybe check to see if something is binding the mechanism. DC There's apparently no fuse for it. There's nothing binding the tracks. The lower back support won't move either... If your seats move by pressing buttons then their are fuse for your power seats - only mechanical seats are not fused. Fuse E3 (30A) is the left seat. Fuse E4 (30A) is the right seat. The control box for both seats is also fused - it is E2 (7.5A) Thanks! It IS the fuse. I took the car to a Porsche specialist. I asked him specifically if it's the fuse. He said there's no fuse for the seats... And "the seat needed to be removed to check all the connections..." ****, some Porsche specialist... Do the seats need to be lubricated at some points? It does emit quite a bit of noise when moving, more like grinding... Thanks again. Flipping stealerships and specialist .... ! SO good NO fuse.. ~!
